Help me solve an arguement...
#870852
12/04/10 03:56 AM
12/04/10 03:56 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
My buddy and I are arguing about a very simple subject I think... I could be wrong. I'm trying to convince him that on a steel block, aluminum headed engine, as it warms up the lash loosens up. He tells me it gets tighter. Please tell me I'm right
Re: Help me solve an arguement...
[Re: DemonDust]
#870853
12/04/10 03:56 AM
12/04/10 03:56 AM
Posts: 2,379 MD
Kevins493
MD
you are correct. Easiest argument to make is the aluminum heads expand at a much higher rate (vs temp) than the steel or moly pushrods. I believe cast iron does as well. just not looking it up now. so basically you are making the pushrod seem "shorter" in relation to the distance between the lifter and the rocker (or technically adjuster) so you have more clearance.
[Re: DemonDust]
#870857
12/04/10 04:10 AM
12/04/10 04:10 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
Your correct, aluminum expands eight times more than steel and cast iron when heated to the same temperatures as each other Google aluminum expansion rates, one of my old Crane Cam catalogs says to set the lash .002 loose when setting the valves on a cold cast iron motor, set them .006 tighter cold with aluminum heads on a cast iron block and set them .012 tighter cold on a aluminum block with aluminum heads. I found that information to be accurate on the first all aluminum street Hemi motor I built and on many other mtors since with iron blocks and aluminum heads you do want to check each motor to make sure those settings is what that motor needs and wants
[Re: Cab_Burge]
#870858
12/04/10 11:04 AM
12/04/10 11:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah I use .006 as the cold/hot difference.. then I also run my lash .010 tighter than spec calls for but still with the .006 difference
[Re: MR_P_BODY]
#870859
12/04/10 11:17 AM
12/04/10 11:17 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Even though it's a pain at times, I always make a point of checking the lash hot. That's what the engine actually sees, so it makes the most sense. Eliminates the guesswork. Minor lash variations can make some significant horsepower swings(both ways) on some engines, so it's always a good idea to have this ironed out. MB
[Re: MR_P_BODY]
#870863
12/04/10 01:51 PM
12/04/10 01:51 PM
Posts: 3,695 nc
emarine01
nc
I guess you dont like roller cam valve chatter
[Re: emarine01]
#870864
12/04/10 01:58 PM
12/04/10 01:58 PM
MR_P_BODY
No its not that... I need all the lift I can get, one of these days when I get a few bucks I'll have it reground for another .100 lift(I went wimpy the first time around)
