HEMI tube seals and plug wires #870168
12/03/10 10:27 AM
12/03/10 10:27 AM
Raleigh, NC
Y
Youngblood Offline OP
Y
Raleigh, NC
I went to my buddy's place yesterday to change out plugs on his HemiCuda. Car is a clone, complete nut and bolt resto. He wanted the plugs changed and had an issue with brake booster.
The plug wires are crap. They need replacement. Also, the tubes were full of oil. What is the best gasket setup for sealing these stock covers? Is there any trick anyone knows of? This car is so nice and so clean, you only want to touch it as little as possible.
Also, what do you recommend for top quality wires? They would have to be correct appearing,date-coded pieces for this car. I hate numbers matching stuff myself. I mean I appreciate them for what they are and all, I just prefer hot rods.
Thanks for any advice, John.
Re: HEMI tube seals and plug wires [Re: Youngblood] #870169
12/03/10 10:37 AM
12/03/10 10:37 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
There is only one company making date coded wires for Mopars, at the moment
Re: HEMI tube seals and plug wires [Re: Youngblood] #870170
12/03/10 10:59 AM
12/03/10 10:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As far as seals go he needs the milodon tube seals that go in the head first and have an o ring , the tubes get oil when the plugs are pulled or he didn't have them installed correctly , need to remove the gasket off the bottom of the plugs , the tube is the gasket .
Re: HEMI tube seals and plug wires [Re: JohnRR] #870171
12/04/10 10:09 AM
12/04/10 10:09 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
