Coil over front end with cal-tracs on rear #869799
12/02/10 07:32 PM
12/02/10 07:32 PM
Iowa
9
9second_bottle Offline OP
Iowa
Does anyone have a coil over front end with cal-tracs on rear. If so how does it work for you, How fast is your car. Thanks
66 Coronet 3720lbs. 9.80 @ 138mph on a bottle
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869800
12/02/10 07:47 PM
12/02/10 07:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Works good so far. I think the coils overs I have are a little stiff though. The front doesn't really rise much, but it hooks hard. Car should be 6.10's in the 1/8th, but technical difficulties have only allowed me to run 7.0 at 100mph....Street car though with mufflers. MF front end, mon leaf caltrac back end.
Caltracs work....
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869801
12/02/10 07:52 PM
12/02/10 07:52 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
i do. i did not get it installed until the end of this season so i only made it out a couple of times. i'm still sorting it out, but it did give me a new best. the previous best at my local track was 10.18 60' was 1.46, last time out went 10.06 @ 134.62 with a 1.42 60' season ended so i'm waiting for next year to start.
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869802
12/02/10 08:00 PM
12/02/10 08:00 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
alterkation front,cal trac back 1st time t&t went awesome worked flawless! 9's w pump gas sb
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869803
12/02/10 08:11 PM
12/02/10 08:11 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
69 charger 3100 lb race weight, coil over front end, cal track monos rear, dana 60, 4.11 gears with a 528 wedge went 8.86 at 163 mph was the best. http://www.youtube.com/watch?v=H96AJ0cfgpY
This pass is when Blake had the car. has coil overs and limiters up front.
Kasey
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869804
12/02/10 09:59 PM
12/02/10 09:59 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Alterkation front end B1, Mid 9's
http://www.youtube.com/watch?v=wTupJMuG3Wo
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869805
12/02/10 10:55 PM
12/02/10 10:55 PM
Iowa
9
Iowa
VERY COOL please keep them coming
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869806
12/04/10 02:05 AM
12/04/10 02:05 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I'm curious as to how it works on a marginal track.
I am running a stock front end with 5" of travel and it is hit and miss on a marginal track. This is one of the things I need to work on this winter. Beep
Re: Coil over front end with cal-tracs on rear [Re: Bigbeep] #869807
12/04/10 02:55 AM
12/04/10 02:55 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have an Alterktion front end and Caltracs mono-leafs and bars on the rear of my Demon.
Sorry I can't post results, it's still in a million pieces.
Re: Coil over front end with cal-tracs on rear [Re: 9second_bottle] #869808
12/04/10 08:32 AM
12/04/10 08:32 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
I think you will be OK as long as you can get plenty of front end upward travel, IIRC Calverts recommend at least 5 inches.
Though I have a stock type front end on my car, I do know a racer who switched to an Alston front clip on his C***y. He didn't have as much front travel with this compared to stock and has been struggling with 60ft times ever since.
Re: Coil over front end with cal-tracs on rear [Re: Tig] #869809
12/04/10 01:25 PM
12/04/10 01:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've considered going coil overs on my street/strip Dart but I think my car is to heavy and doesn't have enough power for the coil overs to work. my Dart is 3260# and runs high 6.50s in the 1/8 with high 1.30 60'. As it sits now I have 5.5" of front travel, most of the coil over shocks I've seen are 5" stroke, so I don't know how much travel you could get with them. Mine's hit and miss on hooking at marginal tracks too.
