Charger R/T hood with a louvered insert from a seller on Moparts. It was billed as very solid with little filler and minimal pitting.
Well, thankfully there is no rust. However, stripping it revealed massively ugly metal damage concealed by 30 pounds of bondo some type of metal based filler.
No response from seller so I must make do.
I need some advice on going forward with restoration. There is severe divoting and pot metal filler on the front right where the flat blends into the radius of the bulge. Same thing in the rear by the hinge areas.
Take a look at the picture and see if any here have a recommendation for repair ideas.
Thanks Moparts.
