Is one Repop Rallye Wheel better or R they the same? #869689
12/02/10 04:47 PM
12/02/10 04:47 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
Friend of mine wants to get a set of Repop Rallye wheels for his Road Runner and had read where some guys had gotten them and they were warped from the "dealer". What do you guys recommend? I think he is upgrading to 15x8"
Joe
65 Barracuda
70 Challenger
Re: Is one Repop Rallye Wheel better or R they the same? [Re: jrwoodjoe] #869690
12/02/10 05:25 PM
12/02/10 05:25 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Good question.
Re: Is one Repop Rallye Wheel better or R they the same? [Re: CDN72SE] #869691
12/02/10 05:32 PM
12/02/10 05:32 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I Have a repo 15x7 wheel here that won't accept a stock trim ring cause the valve stem is not drilled in the right location. I have no idea who made it either. I will weld it shut and redrill it so it can be used....
Re: Is one Repop Rallye Wheel better or R they the same? [Re: QuickBpBp] #869692
12/02/10 11:29 PM
12/02/10 11:29 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
If I remember right,all the repop wheels are made the same using the 1972-4 version wheel,not the 1970-1 style.Smaller triangle openings on the later version.Plus the repops that come powder coated or painted are way off in color if thats a concern.
Re: Is one Repop Rallye Wheel better or R they the same? [Re: 44D6PAKCUDA] #869693
12/03/10 01:44 PM
12/03/10 01:44 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Yep that is a good question , I am interested to hear what is said.
Yes the color is not the same as the orginal color of the wheels. So order yours bare and spend the money to get them blasted and painted correctly. The wheels can be orderd bare , at least from me they can, no problem.
As far as being straight , most are within factory tolerances , and those are pretty loose.
The Wheel Guy
Midwest Vendor for Specialty Wheels.
Re: Is one Repop Rallye Wheel better or R they the same? [Re: duster2] #869694
12/03/10 02:35 PM
12/03/10 02:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've had no issuses with the 15X7 or 15X8 Wheel Vintiques Ralleys that I have on several cars, no problem attaching either 70 or 71 trim rings, repros or originals, plus the welds on the back side are "cleaner" in appearance, and finish/fit,...esp when using large rotor, or rear disc brakes, such as SSBC rotors, factory 15X7's that I have used, often need the welds dressed down to avoid hitting/jambing on the calipers,....my only complaint with Wheels Vintiques is I wish they would get the Ralley Silver" color correct, ...the current powdercoat is too gray
Mike
Re: Is one Repop Rallye Wheel better or R they the same [Re: DAYCLONA] #869695
12/03/10 03:31 PM
12/03/10 03:31 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I bought a set of 15x7 Ralleys about 12 years ago from YO. I had them in the boxes until about 2 years ago when I installed them with new tires. Two of them had such a bad wabble that the manager of the tire shop had to call me in the back to show me how bad they were. He said to have them put on the rear of the car and he warned me that they would vibrate above 60mph or so. They do vibrate at about 75mph+. I have thought about taking them to a machine shop to see how much material it would take (off of the mounting surface) to square them back up but I am partially afraid of removing the material and them still being safe. Stockton Wheel says that the normal runout is .025" but I would bet that mine are out more than that after seeing them spun up on a tire balancer.
One of these days I will buy a new 15x8 set to replace the rears and set these aside.
These do accept the 70 trim rings.
Re: Is one Repop Rallye Wheel better or R they the same [Re: YO7_A66] #869696
12/04/10 11:45 AM
12/04/10 11:45 AM
Tenn.
Tenn.
This is the kind of feedback and info. I'm looking for. Thanks for taking time to post guys.
BTW, that stinks about the YO wheels. That's a problem for a lot of us who take several years to so a project. You buy a piece or part and stick it away only to find out later it doesn't fit, it's wrong etc.
Joe
65 Barracuda
70 Challenger
Re: Is one Repop Rallye Wheel better or R they the same [Re: jrwoodjoe] #869697
12/05/10 02:42 PM
12/05/10 02:42 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Mine are steelies, not rallyes but my Wheel Vintiques that I bought through Summit were badly out of balance. They required multiple weights and the tire store said they'd vibrate above 60mph. Of course I didn't find out until after getting them shipped from the US and getting them sprayed body color so I'm going to use them and hope for the best. Emails to Summit went unanswered. The wheels have been one of the most disappointing aspects of the resto to date.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Is one Repop Rallye Wheel better or R they the same [Re: DPelletier] #869698
12/05/10 02:57 PM
12/05/10 02:57 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Summit is usually very good about customer service. Did you call them?
Were your rims out of round, did they have a lot of runout, or did the tire and rim assembly just require a lot of weight to balance? Did they try repositioning the tires on the rims?
Re: Is one Repop Rallye Wheel better or R they the same [Re: jbc426] #869699
12/05/10 03:39 PM
12/05/10 03:39 PM
DPelletier Offline
DPelletier  Offline
Nope, after a couple emails (which is how I contacted them in the first place) I gave up realizing that the cost of the rims was only 1/3rd of the price of the wheels (the rest was shipping and painting) so even if they gave me another replacement set, it would cost me a bunch more money so I gave up.
Yes the rims had a ton of runout (don't remember the exact figures as it was 3 years ago) and they did reposition the tires to no avail. I also bought another set of the same tires for the 'Cuda at the same time and they mounted on the factory rallyes with no problems.
Re: Is one Repop Rallye Wheel better or R they the same [Re: jbc426] #869700
12/05/10 03:49 PM
12/05/10 03:49 PM
Salem
Grizzly Online tonguue
Moparts Proctologist
Grizzly  Online Tonguue
Salem
You would think it would be tough to " f " something up as simple as a wheel, but once again, the aftermarket comes to the rescue.
Mo' Farts
Moderated by "tbagger".
Re: Is one Repop Rallye Wheel better or R they the same [Re: DPelletier] #869701
12/08/10 03:38 PM
12/08/10 03:38 PM
1.5 hours SE of Pittsburg, Pa
geno440 Offline
geno440  Offline
I don't know about rallyes, but I have purchased two sets of the Chrome Magmun 500 replacement Wheel Vintiques. What a diappointment. First, I could barely get them to balance. They look like they wobble on the balance machine. Then ..... I coated them with protectant over the first winter and in the spring they had rust comming out. Stored in a dry, non-climate controlled garage. Pits.... I called Summit. They said call Wheel Vintiques. I called them. They more or less said sorry bud, the 30 day warranty is up. We will sell you new ones if you wish. I was and still am so disappointed.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: Is one Repop Rallye Wheel better or R they the same? [Re: jrwoodjoe] #869702
12/09/10 12:04 AM
12/09/10 12:04 AM
cataclysm80 Offline
cataclysm80  Offline
Hi Joe Several years back I ordered a set of 15x7 rallyes for my 'cuda from Year One. When I receied them from Year One, they were in Wheel Vintiques boxes. All mounted and balanced fine with the wheel weights on the back side. After mounting the new tires, I discovered that one wheel had a pinhole in the weld and leaked air... manufacture defect. I removed the new tire and returned the wheel to Year One for a replacement. Year One has a very good return policy. Replacement wheel also arrived in a Wheel Vintiques box and the tire mounted and balanced fine.
About a month later a had a shop rebuild the rear end, and they left the lug nuts loose on one of the wheels, Ovaling the mounting holes within a mile of leaving the shop. The shop was good about it and offered to pay for a new wheel, all I had to do was bring them the receipt for my new wheel. I ordered my new wheel directly from Wheel Vintiques. It was quite a bit cheaper than Year One. It matched the other wheels perfectly, and mounted & balanced the same also.
Year One has a good return policy, but you pay for it with the higher prices.
Original (used) wheels also have their problems, scuffs, bent rims, & ovaled holes.
Tav
Re: Is one Repop Rallye Wheel better or R they the same? [Re: jrwoodjoe] #869703
12/09/10 11:11 AM
12/09/10 11:11 AM
Roseville, Mich
rosevillemoparts Offline
Roseville, Mich
we have sold about 80 15x7 and about a dozen 15x8 rims from wheel vintiques this year, We have had minimal to no QC issues. One i can recall did have a pin hole in the inner weld, Never had a balancing issues, and the factory and aftermarket rings fit.
Mopardave
rosevillemoparts.com
If I don't reply to your PM
please email me at parts@mikeriehls.com
http://www.rosevillemoparts.com/
Re: Is one Repop Rallye Wheel better or R they the same [Re: rosevillemoparts] #869704
12/09/10 02:43 PM
12/09/10 02:43 PM
Tenn.
Tenn.
Thanks for all the replies. I sent my buddy a link to this post.
Thanks again, Joe
Re: Is one Repop Rallye Wheel better or R they the same? [Re: QuickBpBp] #869705
12/09/10 08:37 PM
12/09/10 08:37 PM
New Brunswick
U
Unfair Advantage Offline
U
New Brunswick
I don`t understand why more people are not having issues with mounting "true" 15x7 trim rings on Wheel Vintiques 15x7 rallyes. The front offset is wrong.. stock BS is 4.25 which it is ..But the rim is actually narrower now.
By time the trim rim is nearing the catch area, the edge of the trim ring hits the center portion and therefore won`t let the ring fully seat .I sent two back to Summit and gave up !!
Re: Is one Repop Rallye Wheel better or R they the same? [Re: Unfair Advantage] #869706
12/09/10 10:38 PM
12/09/10 10:38 PM
cataclysm80 Offline
cataclysm80  Offline
This reminds me of a guy at the Don Garlits show a few weeks ago that said he ordered his 15x7 trim rings from Summit. The Summit trim rings were cheaper than Mopar trim rings, but he had to trim the inside lip on every trim ring to get it to fit down onto his rallye's. The Summit rings were bottoming out on the wheel center as you described.
Are you sure your trim rings aren't GM or Ford or something?
Tav
Re: Is one Repop Rallye Wheel better or R they the same? [Re: Unfair Advantage] #869707
12/10/10 02:15 PM
12/10/10 02:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hmmmm,.....I have a set of 15X7 Wheel Vintiques Ralleys, and a set of "original" Ralleys that I use on one car, the repros have BFG tires mounted on them for street use, the "originals" have "vintage" polyglas belted tires mounted on them for show use,...I switch the factory center caps and factory trim rings (70 chrome) between each set with NO PROBLEMS or ISSUSES,...
Re: Is one Repop Rallye Wheel better or R they the same? [Re: cataclysm80] #869708
12/16/10 02:37 PM
12/16/10 02:37 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Yes I`m sure they are NOS and original mixes 15x7 rings .I was sent two of the newer wheel versions 2009 {both went sent back one to replace the other } I did not pursure with WV, Summit didn`t know what to say ?? BTW a Vintinque wheel from ~ 3 years ago did fit but new ones will not{same part number. Just trying to save someone a head ache .. I`d like to get to the bottom of this but..
