Re: Which would you do? Stroker vs. 5.7 hemi?
[Re: MN-ScatPack]
#868756
12/01/10 12:36 PM
12/01/10 12:36 PM
Posts: 2,648 GA
Boosted
GA
I would say for a daily driver that you would want to take out of town and enjoy with the top down the 5.7 hemi would be the ticket... You will get some performance, mpg and drive-ability will be allot better also.. And you can put the Hemi emblems on it...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: MN-ScatPack]
#868757
12/01/10 12:49 PM
12/01/10 12:49 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Well the price thing could be argued either way depending on what you use and how good of deals you can get and so could HP. If you are thinking that you want to use stock heads than the 6.1 will be faster, it will make more HP OOTB and weigh a lot less, plus with a big stoker kit in the future and CNC ported stock heads it can make incredible HP, the big block will need heavily worked Victors to keep up in the HP department. Now TQ on the other hand it will be hard for the hemi to keep up as most of the stroker kits for the hemi only get up to 440 or so cubes while the 400 block can swallow over 500 cubes. To make 700 hp with a hemi you add a 440 stroker kit and port the heads, 950hp on a mopar single plane intake or XV intake and big cam and you are there, stock blocks can take it with their cross bolted mains. 700 hp in a 400 block is scarey, you need a good girdle, aluminum caps, aftermarket heads... You will get lots of different takes on the subject but that is my
[Re: MN-ScatPack]
#868758
12/01/10 12:53 PM
12/01/10 12:53 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Phew, tough question of the day....... I would go with the 400 stroker: The car is already set up for it, you can build it to any power level you want, and the maintenance is simple. If you are going for something more modern with the 5.7/6.1 then the engine will be out-dated by the time you are done the swap. That is, the 6.4 is already on it's way out, the 5.7 has already gone through significant changes, and I'm sure Mopar is working on the final version of the Hemi; a 426/7.0 liter. To keep up with the new engines is going to be very expensive. What is it that you want to be able to do with the car?
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#868759
12/01/10 01:18 PM
12/01/10 01:18 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
With a nice stroker engine which is build for torque you don't need 5 or 6 gears nor steep gears in the back. The stock transmission or an A518 with a bigblock-bellhousing and 3.23 gears are more than enough for happy cruising. The Hemi only adds potential 'misery' in the form of a bunch wires, injectors and computer stuff. Sure it will mostlikely get better MPG but other than that probably the only fun-factor is when you open the hood. With a stroker motor the fun happens every time you press the gaspedal...
[Re: Mr.Yuck]
#868762
12/01/10 10:13 PM
12/01/10 10:13 PM
Posts: 5,188 Twin Cities, MN
MN-ScatPack
Twin Cities, MN
Well those are exactly the responses I was looking for. I am not going for 700hp, rather a fun, reliable and snappy ride. I really don't care much about mpg's as this is strictly a "fun" car, not a daily driver (except to work on all nice days, work is only a mile away from home). So, now that I'm leaning towards the 400 stroked, tell me how you would build it. What kit? How many cubes? Heads? six pack? dual 4's? efi? single? others? estimated price (roughly)? I hope this is not asking to much and I'm sure answers will be all over the place, but would be nice to get a bunch of opinions. Again, don't care about high hp, lets just build a fun motor that doesn't break the bank!
[Re: forphorty]
#868765
12/01/10 10:55 PM
12/01/10 10:55 PM
Posts: 2,648 GA
Boosted
GA
The reason I said the 5.7 was that this car is a vert.. I have never been a fan of any vert being on the race car side..
Want more hp than that stroker? Add a turbo tp the 5.7 and run away from the stroker 400. And that is easy... I am looking at a 67 fast back barracuda for a race car and it will have a turbocharged 5.7 in it.. I just do not understand why people are so afraid of wiring...
have a 512 in my Challenger... would I do it again? nope.. everything from here on will be late model stuff...
2011 RAM3500
[Re: Boosted]
#868766
12/01/10 11:00 PM
12/01/10 11:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah put a turbo on a stroker 400 and it will run away from a 5.7. apples to onions there.. easy? it's not EASY to add a turbo to a BB, Let alone fab something up to a new 5.7 or 6.1. And if you keep it injected it becomes more complicated. Not too mention if you want to run a new auto trans or a 5-6 speed you'll have to start cutting up the car. I guess if you own a shop or work for a magazine everything is easy. But for most of us here it is not easy and not a practical build to take on.
[Re: MN-ScatPack]
#868769
12/01/10 11:40 PM
12/01/10 11:40 PM
Posts: 8,498 Candler,NC / Myrtle Beach, SC
JDMopar
I can tell you from experience, that if you want to enjoy the car because it's a convertible....don't get too carried away with the motor. When I built my 71 Challenger conv. back in 92, I put a beast of a 340 six pak motor in it. Sure it ran like a gut shot cat, but it was not much fun just to ride in. I ended up taking the hot 340 out, and replacing it with a mild 360 around 94-95. It's still in there, and the car is MUCH more enjoyable without all the thumping,shaking and having to hunt race gas. If you build a stroker, build a mild 451 that you can run big block HP manifolds on, and get one of Jamie Passons new 5 spds to go behind it. Good luck
[Re: dezduster]
#868772
12/02/10 12:51 AM
12/02/10 12:51 AM
Posts: 587 minot north dakota
ledft79
minot north dakota
I think it all boils down to, do you want to put highway miles on it, or do you want to put 1/4 miles on it? Where is your heart at with this car?
DRIVE EM, DONT HIDE EM.
