Re: 70 4 door satellite fenders/hood fit a 70 roadrunner??
[Re: RocknRoll]
#867593
11/30/10 11:55 PM
11/30/10 11:55 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
the front fenders and hood will fit a 2 door 1970 roadrunner, any body know if this is true.
yes
[Re: RocknRoll]
#867600
12/02/10 01:14 AM
12/02/10 01:14 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
That is the good side. It needs some body work on the passenger fender, it also has hail damage on the top surfaces. I just HAD to have it though. 318 automatic, green interior. Yes, I like green too. No plans for any changes other than paint & body, deffinately no engine 'upgrade'.
[Re: RocknRoll]
#867601
12/03/10 07:14 PM
12/03/10 07:14 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Not only can you use the fenders, but you can use the floors, deck lid, rear panel, and other sheet metal as well. I think the rear extensions and even the lower quarters are the same. Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
