Is it ok to put... #86729
07/10/08 11:21 AM
07/10/08 11:21 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The ECM on the fire wall next to the Volatge regulator? I've seen it done and it looks nice and like it belongs there. I usually put them on the inner fender.
Re: Is it ok to put... [Re: Mr.Yuck] #86730
07/10/08 11:23 AM
07/10/08 11:23 AM
Kirkland, Washington
Pacnorthcuda Offline
no problem, not a bad idea to use some sort of stand-off mounting to get some air circulation around the backside but not critical in my experience
Re: Is it ok to put... [Re: Pacnorthcuda] #86731
07/10/08 11:47 AM
07/10/08 11:47 AM
michigan
black64 Offline
black64  Offline
michigan
The electronics in the modules are usually design to with stand 85 degrees C or 185 degrees F underhood temps. Some of the newer designs have the 105 degree C or 221 degree F components. If the average temp in the mounting area is lower than the above it should live in that mounting location Ok.
Re: Is it ok to put... [Re: Mr.Yuck] #86732
07/10/08 02:38 PM
07/10/08 02:38 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've never had any problems with them on the firewall.
Re: Is it ok to put... [Re: Pacnorthcuda] #86733
07/10/08 02:59 PM
07/10/08 02:59 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah I was thinking of making a bracket to mount it on. Thanks. Anybody got a picture?
