Performer RPM under E body hood? #866979
11/30/10 01:27 AM
11/30/10 01:27 AM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Factory Bulge Hood on this 'Cuda. I need to know if it will fit with Holley or Edelbrock/Carter carb and a stock style air cleaner???
Re: Performer RPM under E body hood? [Re: Bob_Coomer] #866980
11/30/10 02:11 AM
11/30/10 02:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
pretty sure it fits, but I think some folks have to run a drop base on the air filter/cleaner.
**Photobucket sucks**
Re: Performer RPM under E body hood? [Re: Bob_Coomer] #866981
11/30/10 02:19 AM
11/30/10 02:19 AM
Midwest
MoparsnMissiles Offline
Midwest
I have 70 Challenger, R/T hood (bulge type), Edelbrock RPM Air Gap intake with Edelbrock carb and stock dual snorkel air cleaner. About 3/4" to 1" of clearance, air cleaner to hood. It's close but works fine. Running this way for over two years now and NO problems at all.
Hope this helps, but I would measure closely before slamming the hood regardless. I used a wad of clay in several places on top of the air cleaner and closed hood slowly and progressively until sure of clearance.
Re: Performer RPM under E body hood? [Re: MoparsnMissiles] #866982
11/30/10 09:49 AM
11/30/10 09:49 AM
Colorado
67plymouthman Offline
Colorado
I use it on my 70 Callenger 440 w/a drop base and 3 in element. Not a lot of spare room but it works. I do have the sport hood.
Re: Performer RPM under E body hood? [Re: 67plymouthman] #866983
11/30/10 10:46 AM
11/30/10 10:46 AM
NY usa
540challenger Offline
NY usa
I jave a 71 challenger stock flat hood.
I am running a 408 small block with an air gap. I have a drop base with a 1spacer under the air cleaner "clear the throttle linkage" i have about 1 inch of clearance under the hood but i run poly locks on my motor.
Re: Performer RPM under E body hood? [Re: 540challenger] #866984
11/30/10 11:14 AM
11/30/10 11:14 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
My buddy had to run a kick down cable on his due to intake height.
Re: Performer RPM under E body hood? [Re: wally426ci] #866985
11/30/10 12:25 PM
11/30/10 12:25 PM
Rock Springs
Rock Springs
Thanks Guys
good point, I plan to use a stock kick down linkage, and just realized this might be a problem.
Re: Performer RPM under E body hood? [Re: Bob_Coomer] #866986
11/30/10 12:41 PM
11/30/10 12:41 PM
NY usa
NY usa
Thanks Guys
I running the stock kick-down linkage on mine however it is the 3-way adjustable version
Re: Performer RPM under E body hood? [Re: 540challenger] #866987
11/30/10 02:02 PM
11/30/10 02:02 PM
CA
mojavered Offline
mojavered  Offline
CA
I am running an RPM Performer on a 440 with a Proform carb in a 71 Chally with the Rallye hood. The air cleaner has about a 1.5" drop base on it. I have only enough room for a hex nut to hold down the air filter top or I touch the bottom of the hood and I do not have any insulation under there. (I know, it's not a Cuda)
71 Challenger RT
440 / 727 / 8.75
Re: Performer RPM under E body hood? [Re: Bob_Coomer] #866988
11/30/10 02:15 PM
11/30/10 02:15 PM
Kirkland, Washington
Pacnorthcuda Offline
Assuming you're talking an RB motor--no it won't, at least not with the stock air cleaner.
I too run a 440/eddyRPM/Holley carb and I have to use a pretty deep drop base to clear a 3" filter.
Stock air cleaner will sit too high.
Re: Performer RPM under E body hood? [Re: Pacnorthcuda] #866989
11/30/10 03:17 PM
11/30/10 03:17 PM
Midwest
Midwest
Sorry, should have been a little clearer with my response. Mine's a "B" engine and has about 1" clearance. Makes sense that the "RB's" then would not have enough clearance.
Re: Performer RPM under E body hood? [Re: Pacnorthcuda] #866990
11/30/10 04:51 PM
11/30/10 04:51 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Drop base can be an issue with the stock kickdown rod, but it can be done if you use a 1/2" riser below the drop base (edelbrock part avail at most A.P. Stores). this negates 1/2" of what you're gaining with the drop base to begin with, though. going with a Lokar cable setup creates the room needed, but gets away from the stock look. At the very least, you could wrap the lokar cable in a black sheath (thinking shrink wrap) to make at least blend in (???).
Re: Performer RPM under E body hood? [Re: StealthWedge67] #866991
11/30/10 09:09 PM
11/30/10 09:09 PM
NJ
440challenger Offline
NJ
yep,drop base, 2in element, k&n extreme lid
Re: Performer RPM under E body hood? [Re: Bob_Coomer] #866992
11/30/10 09:27 PM
11/30/10 09:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not a Cuda, but might help.
Standard kickdown linkage, but slightly modified.
Re: Performer RPM under E body hood? [Re: BSB67] #866993
05/12/11 12:12 AM
05/12/11 12:12 AM
OH-IO
moparman383 Offline
moparman383  Offline
OH-IO
I'm running a 383 in my 71 Challenger, with an Eddy Performer RPM and a 750 dp Holley. I'm currently running a drop base air cleaner with a low 1.5-2" filter and K&N Xtreme style top flow lid. I can't see any way this is going to be within 2" of fitting. I was previously running a T/A hood and switching to an R/T hood.
Any suggestions? Surely someone else here has this combo eng/manifold/hood.
thanks.
Re: Performer RPM under E body hood? [Re: moparman383] #866994
05/12/11 11:25 AM
05/12/11 11:25 AM
OH-IO
moparman383 Offline
moparman383  Offline
OH-IO
No one else running a 383 with Performer RPM intake under an R/T hood??
Re: Performer RPM under E body hood? [Re: moparman383] #866995
05/16/11 06:49 PM
05/16/11 06:49 PM
OH-IO
moparman383 Offline
moparman383  Offline
OH-IO
Update, even though nobody responded. An Eddy RPM Performer on a 383 with an R/T hood WILL fit. I don't know how but it fits.
Re: Performer RPM under E body hood? [Re: moparman383] #866996
05/16/11 07:03 PM
05/16/11 07:03 PM
Nebraska
70VcodeCoronetRT Online tonguue
70VcodeCoronetRT  Online Tonguue
Nebraska
Cool, thanks . What air cleaner you running?
Re: Performer RPM under E body hood? [Re: 70VcodeCoronetRT] #866997
05/16/11 08:10 PM
05/16/11 08:10 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Probally because it is a Low deck block...
My 2cents....
What linkage setup did u use?
