Performer RPM under E body hood?
#866979
11/30/10 01:27 AM
11/30/10 01:27 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Factory Bulge Hood on this 'Cuda. I need to know if it will fit with Holley or Edelbrock/Carter carb and a stock style air cleaner???
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Performer RPM under E body hood?
[Re: Bob_Coomer]
#866980
11/30/10 02:11 AM
11/30/10 02:11 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
pretty sure it fits, but I think some folks have to run a drop base on the air filter/cleaner.
**Photobucket sucks**
[Re: Bob_Coomer]
#866981
11/30/10 02:19 AM
11/30/10 02:19 AM
Posts: 116 Midwest
MoparsnMissiles
Midwest
I have 70 Challenger, R/T hood (bulge type), Edelbrock RPM Air Gap intake with Edelbrock carb and stock dual snorkel air cleaner. About 3/4" to 1" of clearance, air cleaner to hood. It's close but works fine. Running this way for over two years now and NO problems at all.
Hope this helps, but I would measure closely before slamming the hood regardless. I used a wad of clay in several places on top of the air cleaner and closed hood slowly and progressively until sure of clearance.
[Re: Bob_Coomer]
#866986
11/30/10 12:41 PM
11/30/10 12:41 PM
Posts: 2,826 NY usa
540challenger
NY usa
My buddy had to run a kick down cable on his due to intake height.
Thanks Guys good point, I plan to use a stock kick down linkage, and just realized this might be a problem.
I running the stock kick-down linkage on mine however it is the 3-way adjustable version
[Re: 540challenger]
#866987
11/30/10 02:02 PM
11/30/10 02:02 PM
Posts: 93 CA
mojavered
CA
I am running an RPM Performer on a 440 with a Proform carb in a 71 Chally with the Rallye hood. The air cleaner has about a 1.5" drop base on it. I have only enough room for a hex nut to hold down the air filter top or I touch the bottom of the hood and I do not have any insulation under there. (I know, it's not a Cuda)
71 Challenger RT 440 / 727 / 8.75
[Re: Bob_Coomer]
#866988
11/30/10 02:15 PM
11/30/10 02:15 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
Assuming you're talking an RB motor--no it won't, at least not with the stock air cleaner. I too run a 440/eddyRPM/Holley carb and I have to use a pretty deep drop base to clear a 3" filter.
Stock air cleaner will sit too high.
[Re: Pacnorthcuda]
#866989
11/30/10 03:17 PM
11/30/10 03:17 PM
Posts: 116 Midwest
MoparsnMissiles
Midwest
Sorry, should have been a little clearer with my response. Mine's a "B" engine and has about 1" clearance. Makes sense that the "RB's" then would not have enough clearance.
