TRW 2295 piston to valve clearance question #865926
11/28/10 09:48 PM
11/28/10 09:48 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
im wondering what you guys have run as far as lift with 2295's in a 440. would i be safe to think about a 600 lift roller? of course i will clay the valve reliefs. also what kind of rpm have you turned these heavy domes?? 1100 grams i think?? wow!
74 dart sport 440 www.Csucarbs.com
Re: TRW 2295 piston to valve clearance question [Re: shoebox] #865927
11/28/10 10:00 PM
11/28/10 10:00 PM
Az
Crizila Offline
Crizila  Offline
Az
Only way to know for sure is moc it up and measure it.
Fastest 300
Re: TRW 2295 piston to valve clearance question [Re: shoebox] #865928
11/28/10 10:05 PM
11/28/10 10:05 PM
okla.
sam64 Offline
sam64  Offline
okla.
i don't think you will have any problems,those pistons sit down the hole more than 2355.i've got a 640 roller with those pistons.cracked cylinder that the machine shop didn't catch reared it head upon breakin so its in the corner for now.
