WAR Fish runs 8.22@162 *with video*
#865597
11/28/10 01:29 PM
11/28/10 01:29 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
Re: Flying Fish 8.22@162
[Re: MegaDart]
#865599
11/28/10 01:45 PM
11/28/10 01:45 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
who or what is Flying Fish?? Nice slip, looks almost identical to what my Dart runs.
[Re: S/ST 3040]
#865603
11/28/10 05:45 PM
11/28/10 05:45 PM
StripeHOG
Kokomo,IN
facebook LOL, yesterday he had a 1.148 60' so I assume the 1.20 60' on the 8.22 run was with the back tires
[Re: StripeHOG]
#865604
11/28/10 05:49 PM
11/28/10 05:49 PM
StripeHOG
Kokomo,IN
heck looking at the 330 he may have spun on the 8.22 pass, I guess that would explain the high MPH
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
[Re: StripeHOG]
#865616
11/28/10 07:50 PM
11/28/10 07:50 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
actually what probably happened is the clutch was set up better on the 25 run and slipped more off the starting line and at the bottom of gear changes therefore not driving as hard through the gears.. then with the clutch tight it pulled the motor down and didnt 60' as well but ran the rest better...
you can usually tell from his light,,, if its a slower light id say the clutch was set up loose,, and it slipped... charlie is usually good on the tree
but only he would beable to answer this correctly,,, maybe me posting this will bring him back on here,, cause if you ever seen before,,, he likes to tell me im wrong
