Re: Do Mustang GT wheels work?
[Re: Coronet-R/T-Rag]
#86533
07/09/08 10:27 PM
07/09/08 10:27 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
On a Coronet R/T? Some cars are more tolerant of the large backspace than others. A couple years back, someone on Moparts posted photos of their Coronet R/T (69 model) with 17x9 or 17x10 wheels on the rear for sure, and maybe on the front as well. I've slept since I saw it, but I remember being amazed at how well the wheels fit with no mods. The hub bores on the Mustang wheels are going to be too small to fit the Mopar hub, so you'll probably have to use spacers like Jerry's with the proper hub sizes, or have the wheels machined to fit the Mopar hub. Ideally, you should have the wheels opened up to 73mm so you can use common wheel hub rings to fit the Mopar hub. Then you have wheels that aren't Mopar-specific if you want to sell them in the future.
Clair
[Re: AndyF]
#86537
07/10/08 04:52 PM
07/10/08 04:52 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
my car with 255/50R17's and pre-05 mustang wheels (5.72" backspace). I'm using .75" thick bolt on adapters/spacers.
a board member had the same setup (albeit Mach1 rims vs. bullits) on a '69 roadrunner and it fit fine.
the '05-up 17x8 mustang rims are more like 6.3" backspace, so you'd need a 1.25-1.5" spacer
[Re: patrick]
#86539
07/10/08 10:37 PM
07/10/08 10:37 PM
Clair_Davis
Fort Worth, TX
The wide 5-spoke wheel used on many of the 05+ GT's is 18x8.5, and has something like a 50mm offset.
Clair
[Re: Clair_Davis]
#86540
07/11/08 01:04 AM
07/11/08 01:04 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I have some older 16x8's.Shod with 205 55's. They look to be 5 1/2" or a little bigger on the BS'ing.
I am going A body factory discs, '66 B body rear.
I don't like the idea of using spacers!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#86541
07/11/08 08:29 AM
07/11/08 08:29 AM
patrick
Grand Haven, MI
rug, you might have to. I don't think a 16x8" stang rim (should be the same 5.72" BS as the 17x8's if it's from the mid-90's thru '04 vintage) will clear the upper ball joint or tie rod end with that much backspace. a 17" will.
[Re: patrick]
#86542
07/11/08 08:39 AM
07/11/08 08:39 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
my 70 Dart was running 14x7 Magnum 500s from a Mustang, correct backspacing and bolt pattern. They are still on the car somewhere in california too. I had 75 A-Body disc brakes on them and they fit but if you have aftermarket like wilwood I think you need a larger sized rim
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Rug_Trucker]
#86544
07/11/08 11:22 AM
07/11/08 11:22 AM
patrick
Grand Haven, MI
well, if he got them to fit, then they should work. with that much backspace, the rim goes OVER the UBJ and OTRE. without spacers, my outer tie rod end was within 1/4-1/2" of the rim on my M body, and the zerk of my UBJ is within about 3/8" or so.
no idea on sanctioning body legality, but if you use bolt on adapters made from good material (billet AL, steel), they're just as strong or stronger than the flange coming off you're rear axle, if you use hub-centric "through" spacers with long enough studs, the studs only see tensile load, no bending load, so, as long as the lugs are properly torqued they're safe. heck, A LOT of offroaders use wheel spacers, and some 3/4 and 1 ton truck came with them OEM.
