Do Mustang GT wheels work? #86530
07/09/08 09:57 PM
07/09/08 09:57 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
I've seen Mustang Gt takeoffs really cheap on line. Has anybody run these? Is the backspacing usable?
Re: Do Mustang GT wheels work? [Re: Coronet-R/T-Rag] #86531
07/09/08 10:06 PM
07/09/08 10:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A few people have them on older mopars. From what I understand you need to use wheelspacers since they have a lot of backspacing.
I think they look pretty good if you get the right size tires on them.
Re: Do Mustang GT wheels work? [Re: Neil] #86532
07/09/08 10:12 PM
07/09/08 10:12 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i run the mustang take offs on my e body. nice looking wheels and really cost effective. i also make the wheel spacers to make them hub centric.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Do Mustang GT wheels work? [Re: Coronet-R/T-Rag] #86533
07/09/08 10:27 PM
07/09/08 10:27 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
On a Coronet R/T? Some cars are more tolerant of the large backspace than others. A couple years back, someone on Moparts posted photos of their Coronet R/T (69 model) with 17x9 or 17x10 wheels on the rear for sure, and maybe on the front as well. I've slept since I saw it, but I remember being amazed at how well the wheels fit with no mods. The hub bores on the Mustang wheels are going to be too small to fit the Mopar hub, so you'll probably have to use spacers like Jerry's with the proper hub sizes, or have the wheels machined to fit the Mopar hub. Ideally, you should have the wheels opened up to 73mm so you can use common wheel hub rings to fit the Mopar hub. Then you have wheels that aren't Mopar-specific if you want to sell them in the future.
Clair
Re: Do Mustang GT wheels work? [Re: Clair_Davis] #86534
07/10/08 03:57 PM
07/10/08 03:57 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
just something to think about. what mustang wheels are you talking about? off of the new body style, or 94-04(think they were all about the same). it seems like the new body style would have a different backspacing. my sister put the 99-04 body style bullit wheels on her 68 stang and it looks cool.
Re: Do Mustang GT wheels work? [Re: Coronet-R/T-Rag] #86535
07/10/08 04:04 PM
07/10/08 04:04 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
iirc, the newer mustang 17" wheels have ~5.75" of backspace. the bolt pattern is the same (4.5"), but you'll probably need at least a 1" spacer for a proper fit. i hear that they're a great wheel for the $$$ though, but i always thought there wasn't enough "dish" to the new mustang wheels.
Re: Do Mustang GT wheels work? [Re: Coronet-R/T-Rag] #86536
07/10/08 04:22 PM
07/10/08 04:22 PM
AndyF Online content
AndyF  Online Content
The Mustang rims work great on older Mopars with a 235/55 tire. You may need a spacer depending on which vehicle you have and which brake setup is on the car.
Re: Do Mustang GT wheels work? [Re: AndyF] #86537
07/10/08 04:52 PM
07/10/08 04:52 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
my car with 255/50R17's and pre-05 mustang wheels (5.72" backspace). I'm using .75" thick bolt on adapters/spacers.
a board member had the same setup (albeit Mach1 rims vs. bullits) on a '69 roadrunner and it fit fine.
the '05-up 17x8 mustang rims are more like 6.3" backspace, so you'd need a 1.25-1.5" spacer
2017 Grand Cherokee Overland
Re: Do Mustang GT wheels work? [Re: patrick] #86538
07/10/08 07:43 PM
07/10/08 07:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Yep
No spacer in front, rear 1.125" studded adapter. 255/50-17s all around.
Re: Do Mustang GT wheels work? [Re: patrick] #86539
07/10/08 10:37 PM
07/10/08 10:37 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
The wide 5-spoke wheel used on many of the 05+ GT's is 18x8.5, and has something like a 50mm offset.
Clair
Re: Do Mustang GT wheels work? [Re: Clair_Davis] #86540
07/11/08 01:04 AM
07/11/08 01:04 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I have some older 16x8's.Shod with 205 55's. They look to be 5 1/2" or a little bigger on the BS'ing.
I am going A body factory discs, '66 B body rear.
I don't like the idea of using spacers!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Do Mustang GT wheels work? [Re: Rug_Trucker] #86541
07/11/08 08:29 AM
07/11/08 08:29 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
rug, you might have to. I don't think a 16x8" stang rim (should be the same 5.72" BS as the 17x8's if it's from the mid-90's thru '04 vintage) will clear the upper ball joint or tie rod end with that much backspace. a 17" will.
Re: Do Mustang GT wheels work? [Re: patrick] #86542
07/11/08 08:39 AM
07/11/08 08:39 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
my 70 Dart was running 14x7 Magnum 500s from a Mustang, correct backspacing and bolt pattern. They are still on the car somewhere in california too. I had 75 A-Body disc brakes on them and they fit but if you have aftermarket like wilwood I think you need a larger sized rim
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Do Mustang GT wheels work? [Re: patrick] #86543
07/11/08 08:58 AM
07/11/08 08:58 AM
Rug_Trucker Offline
Rug_Trucker  Offline
Mine have the large flower petal looking plastic center with the pony.
They came from Hotroddave40 in a round about way. He tried them on his '68 Cuda with the the BBP discs, and 66 B body rear. Said he mounted the empty wheel, just never drove it.
Are spacers safe?
Are they legal at the track?
Re: Do Mustang GT wheels work? [Re: Rug_Trucker] #86544
07/11/08 11:22 AM
07/11/08 11:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, if he got them to fit, then they should work. with that much backspace, the rim goes OVER the UBJ and OTRE. without spacers, my outer tie rod end was within 1/4-1/2" of the rim on my M body, and the zerk of my UBJ is within about 3/8" or so.
no idea on sanctioning body legality, but if you use bolt on adapters made from good material (billet AL, steel), they're just as strong or stronger than the flange coming off you're rear axle, if you use hub-centric "through" spacers with long enough studs, the studs only see tensile load, no bending load, so, as long as the lugs are properly torqued they're safe. heck, A LOT of offroaders use wheel spacers, and some 3/4 and 1 ton truck came with them OEM.
Re: Do Mustang GT wheels work? [Re: Rug_Trucker] #86545
07/11/08 11:23 AM
07/11/08 11:23 AM
dogdays Offline
dogdays  Offline
When I put the 2500 Ram 17" alloys on my '93Sub I had to use a 5/16" spacer to get the wheels to fit over the front suspension, this after massaging the upper A-arms quite a bit. This is on a 3/4 ton 4WD Suburban that is plenty heavy on the front end. I have had absolutely no problems with the spacers, about 25K miles so far.
If you are worried about spacers get together with Bill Rolik's website.
R.
Re: Do Mustang GT wheels work? [Re: Coronet-R/T-Rag] #86546
07/11/08 11:39 AM
07/11/08 11:39 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
They work on the non-performance stuff too. I ran a set of 17" GT rims on my 02 Intrepid, and a set of 16" Pony wheels on a Caravan. A little massaging of the center hole and a thin spacer to clear the brake pads and they fit fine.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
