oiling a 5.7 hemi #865012
11/27/10 08:32 PM
11/27/10 08:32 PM
Vernon, NJ
P
PDFrogman Offline OP
P
Vernon, NJ
the 5.7 hemi on my 04 durango threw a rod after 198K. I found a
a low mileage replacement. it's been out tof the vehicle since may 2010 I want to rpe oil it before I crank it over
my question is how?
FRANK 1970 Road Runner sold! 1969 Sport Satellite convert 1973 383 Challenger six pack 2004 Hemi Durango 2006 jeep grand Cherokee limited
Re: oiling a 5.7 hemi [Re: PDFrogman] #865013
11/27/10 09:06 PM
11/27/10 09:06 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
going to be a challenge. oil pump is eccentric on crank in front of timing chain cover.
Re: oiling a 5.7 hemi [Re: hemibeep] #865014
11/27/10 09:09 PM
11/27/10 09:09 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Why does that matter. Rig something to pump oil under pressure, or if you're handy, I used to use stuff like MT refrigerant cans, put some oil in there, pressurize with air, and pump oil through the sender port. You can wrench or bump the engine slowly over while you do this
Re: oiling a 5.7 hemi [Re: Yancy Derringer] #865015
11/28/10 12:32 PM
11/28/10 12:32 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Sound like the old way of priming can't be done. What I would do is install the engine without any spark plugs installed. This will prevent any compression from building. I would then use the engines' atarter to crank the engine until the oil pressure comes up. Least likly way to do damage.
1979 Chrysler 300 1968 Barracuda project
