64 plymouth single headlight grille #864899
11/27/10 06:28 PM
11/27/10 06:28 PM
s e mich
ro23car Offline OP
ro23car  Offline OP
s e mich
does anyone have illustrations or pics top and bottom of a single headlight grille.
Re: 64 plymouth single headlight grille [Re: ro23car] #864900
11/27/10 06:34 PM
11/27/10 06:34 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'm not sure how the factory did the mods, but here is a picture of Mark Howe's '64 Plymouth. I don't think it's how the factory did it, but it looks simple to do it this way.
Floyd Lippencott IV
Re: 64 plymouth single headlight grille [Re: mr_340] #864901
11/27/10 06:35 PM
11/27/10 06:35 PM
tboomer Offline
tboomer  Offline
Might be something here...
http://www.moparsbymosher.com/index.htm
Re: 64 plymouth single headlight grille [Re: tboomer] #864902
11/27/10 07:48 PM
11/27/10 07:48 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Re: 64 plymouth single headlight grille [Re: topbrent] #864903
11/27/10 07:52 PM
11/27/10 07:52 PM
s e mich
ro23car Offline OP
ro23car  Offline OP
s e mich
topbrent do you have a pic of how the pieces overlap the grille to the headlight doors? thats the part i need to see. and thank you to everyone for all the help.
Re: 64 plymouth single headlight grille [Re: ro23car] #864904
11/27/10 08:07 PM
11/27/10 08:07 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
That dang 'glass scoops look like ass...
Big gaps on the leading edges and the ubiquitous sag in the middle.
Re: 64 plymouth single headlight grille [Re: ro23car] #864905
11/27/10 09:01 PM
11/27/10 09:01 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Not sure if this helps.
Re: 64 plymouth single headlight grille [Re: topbrent] #864906
11/27/10 09:15 PM
11/27/10 09:15 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Home made
Re: 64 plymouth single headlight grille [Re: Frito] #864907
11/28/10 12:12 PM
11/28/10 12:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I've thought about doing that
Re: 64 plymouth single headlight grille [Re: bigdad] #864908
11/28/10 12:55 PM
11/28/10 12:55 PM
s e mich
ro23car Offline OP
ro23car  Offline OP
s e mich
thats the plan for my car for next year.
Re: 64 plymouth single headlight grille [Re: ro23car] #864909
11/28/10 05:15 PM
11/28/10 05:15 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
www.kingoftrim.com They do many of these grilles and other trim parts.I'm sure Mosher uses them as well.
Nautilus Racing-
Re: 64 plymouth single headlight grille [Re: Chris2581] #864910
11/28/10 07:45 PM
11/28/10 07:45 PM
Utah
topbrent Offline
topbrent  Offline
Utah
That places quality has gone downhill. My brother got a 64 Plymouth grille from him last year and it looked absolutely awful. We returned it and got our money back.
Mosher and his crew have been doing a lot of the trim work in-shop lately.
Re: 64 plymouth single headlight grille [Re: topbrent] #864911
11/28/10 08:48 PM
11/28/10 08:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks like the add-on panels go over the center grille, and use the vertical part to register on the grille. Lamp bezels appear to then go over the add-ons, and are trimmed to remove the inner lamp openings.
Screws appear to hold the 5 pieces together, so they'd have to overlap unless there's a backer strip, which might be a good idea anyway.
I would think a taller center brace would help with the dip in the scoop opening; also a common problem on maxie scoops.
I'm SO tempted to do the grille & scoop thing on my '64 Savoy wagon if I keep it.
Re: 64 plymouth single headlight grille [Re: topside] #864912
11/28/10 09:08 PM
11/28/10 09:08 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
They did overlap but rivets instead of screws.
Re: 64 plymouth single headlight grille [Re: ro23car] #864913
11/28/10 09:24 PM
11/28/10 09:24 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
come down and take a look
Re: 64 plymouth single headlight grille [Re: prochargedhemi] #864914
11/28/10 11:49 PM
11/28/10 11:49 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Some body's pic here on Moparts.
Re: 64 plymouth single headlight grille [Re: prochargedhemi] #864915
11/29/10 10:47 PM
11/29/10 10:47 PM
s e mich
ro23car Offline OP
ro23car  Offline OP
s e mich
thanks john pm me your # and thanks to all that helped.
