well been looking over andys book and at the info i got for most of you guys and i think i have some what of a plan..its not set in stone but if all looks good i will start to pick up some of the little things i need for the build..
block /400 stroked to 512/block will be studded with some good main caps and a girdle..
heads / indy 440-1
rockers /t@d 1.6 rollers
intake / 440-2 single with 2"spacer to run 4500
cam / lunati
282@50457 lobe lift
685 gross 1.5
731 gross 1.6
26 lash
108 i think it is
headers / 2" tti /or 2 1/8 custom, out to muff.
trans /727
verta / 9.5 dynamic 5000 or 8" 5600 turbo action
susp. / right now i have ss springs but plan to upgrade to ladder bar susp. later
fuel / 8 gal cell 1/2 line from cell to front of car
body/ 70 duster mini tubbed and will be installing cage/ two race seats/ and plan to put on glass hood, bumpers,deck.
gear / i was thinking 4.10/4.30
tire/ 29/10.5 on a (8 or 10 rim)
ing. will be msd 7al-2 and whatever else thats needed..
ok lets here what should be changed and what needs to be changed and will i make my mark 6.00 in the 1/8 mile..
now dont be shy guys lets hear it
