budget converter #864703
11/27/10 12:46 PM
11/27/10 12:46 PM
central new york
pettyblue440 Offline OP
central new york
I know this is a popular and touchy subject. I am looking at the PTC converter from Cope. Has anyone used these or something in the same ballpark? ($300)
Re: budget converter [Re: pettyblue440] #864704
11/27/10 12:53 PM
11/27/10 12:53 PM
tboomer Online work
tboomer  Online Work
It all depends on what the intended use is...I am sure John won't steer you wrong...
Re: budget converter [Re: tboomer] #864705
11/27/10 12:59 PM
11/27/10 12:59 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I would not consider a unit from PTC as a "Budget" unit. If you can afford one of theirs you are buying a high quality converter. Now an Alabama Boss Hog (ACC), Dayco, Allstar are budget priced converters with hit and miss quality. (GER from a decade ago)
Keep old mopars alive.
Re: budget converter [Re: 2boltmain] #864706
11/27/10 01:02 PM
11/27/10 01:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
turbo action 10" around $400. very good converters.
Re: budget converter [Re: pettyblue440] #864707
11/27/10 04:16 PM
11/27/10 04:16 PM
I have made the mistake of buying Hi Po car parts based on prices, don't do it When it comes to many Hi Po parts I treat them like brain sugeons now, I don't want the cheapest one availble My message is when it comes to converters, cams, tires and so on,is to buy the best one for your car, no matter what
Re: budget converter [Re: Cab_Burge] #864708
11/27/10 04:20 PM
11/27/10 04:20 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I tend to agree with Cab here.
I'll skimp on valve covers and air cleaner bases as long as they fit and work.
A cheap converter will work just fine if the Gods are smiling and you get lucky and the stars align and that penny you found was in fact shiny and face up.
But that rarely happens to me.
Re: budget converter [Re: Cab_Burge] #864709
11/27/10 04:23 PM
11/27/10 04:23 PM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
Im going to add a part to that list.... Dampers!
I got so much heat for trying to skimp out on one that I bout a Fluid Damper. Everyone said dont go budget in this area.
Don
Street/Strip 73 Barracuda
Re: budget converter [Re: The Cuda Guy] #864710
11/27/10 11:53 PM
11/27/10 11:53 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
give this guy a email larry www.chrismantorqueconverters.com
best sevice and price ,9 inch ,bullet back good for 700 hp 380$ .tell him ian from australia sent ya
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: budget converter [Re: Ian] #864711
11/28/10 12:39 AM
11/28/10 12:39 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I was not aware that PTC converters were known as "Cheap".
Re: budget converter [Re: Ian] #864712
11/28/10 04:36 AM
11/28/10 04:36 AM
That is a heck of a deal and the 9" only weighs 1x pound over the 8 inch!
Don
Re: budget converter [Re: pettyblue440] #864713
11/28/10 05:02 AM
11/28/10 05:02 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
I've had a PTC 8IN in my car for 4 year's and it work's just as they said it would.Stall's right at what it's should.Tho mine cost a little more then $300.
Re: budget converter [Re: The Cuda Guy] #864714
11/28/10 08:56 AM
11/28/10 08:56 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Don
don buy my 9" verter
Mopar Performance
