after doing mine in the car with headers and it still leaked
![](/ubbthreads/images/graemlins/rant.gif)
I pulled the engine and did it right and did all the gaskets,except the heads
3 rattle cans of paint and done no header leaks,oil leaks,very clean and purdy
![](/ubbthreads/images/graemlins/drool5.gif)
its not what ya want to hear I know...but in the long run ya will learn mopar and wheen ya self off the ferd and chivy way of doing stuff
![](/ubbthreads/images/graemlins/laugh2.gif)
you will need to remove 1 header from the car
one header loose,might as well drop it
steering linkage should be droped all together from tie rod to tie rod and center as a 1 piece
ya gots to raise the engine up and thats needs undoing..watch the dist when jacking
do not jaack using the balencer and pullys.best lift the engine with a hoist IMO
see...just pull it,seal it,pimp it,install it
![](/ubbthreads/images/graemlins/beer.gif)
