70 B-body white door plug kit #864547
11/27/10 12:08 AM
11/27/10 12:08 AM
BLACKHEMIRR Offline OP
Does anyone know where a white door plug kit would be available? Thanks
Re: 70 B-body white door plug kit [Re: BLACKHEMIRR] #864548
11/27/10 02:05 AM
11/27/10 02:05 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Don't know about an entire kit but here is a link to some white plugs..
http://www.clipsandfasteners.com/1_2_White_Plastic_Flush_Type_Hole_Plugs_7_8_Head_p/pas9829-50.htm
Just my $0.02...
Re: 70 B-body white door plug kit [Re: BLACKHEMIRR] #864549
11/27/10 02:07 PM
11/27/10 02:07 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
they were all black from the factory regardless of paint color. just looking for something different? If so you'll need to measure and find something intended for another application.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 B-body white door plug kit [Re: DPelletier] #864550
11/27/10 03:07 PM
11/27/10 03:07 PM
Canada
demon Offline
demon  Offline
Canada
not true
there were black,white,blue,green,burnt orange,red,tan and others too.
I need white ones as well
Re: 70 B-body white door plug kit [Re: demon] #864551
11/27/10 03:13 PM
11/27/10 03:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
not true
I've worked on allot of Mopars through the years... Never seen any color other than black.. If colors existed they sure weren't used on most of the cars... Maybe later model stuff? One plant?
Re: 70 B-body white door plug kit [Re: 1_WILD_RT] #864552
11/27/10 03:21 PM
11/27/10 03:21 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
i have a low mile 70 charger white guts and i have white plugs...they are factory,i could use new ones cause mine are getting yellow...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: 70 B-body white door plug kit [Re: demon] #864553
11/27/10 05:13 PM
11/27/10 05:13 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
not true
I have maroon coloured ones in my 68 GTX and my parts car had 2 maroon ones in the upper holes and two black ones in the lower holes.
Maybe later ones were all black, but certainly coloured ones were to be had in '68.
Re: 70 B-body white door plug kit [Re: superwrench] #864554
11/27/10 05:44 PM
11/27/10 05:44 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
From memory the colored ones were used at the front of the door area and where a hard plastic where the black were used along the bottoms and were a rubber product.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 B-body white door plug kit [Re: sublimehemi] #864555
11/27/10 06:23 PM
11/27/10 06:23 PM
Canada
demon Offline
demon  Offline
Canada
Also the tiny plug used to access the vent window Allen bolt was colored too.
Re: 70 B-body white door plug kit [Re: demon] #864556
11/27/10 06:34 PM
11/27/10 06:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah, I've seen colors in that location.. Just not the ones covering the bolts holding the vent wing assemblies... But it sounds like they were more common than I would have expected... Still wonder if it varied from plant to plant..
Re: 70 B-body white door plug kit [Re: 1_WILD_RT] #864557
11/27/10 07:30 PM
11/27/10 07:30 PM
DPelletier Offline
DPelletier  Offline
not true
Yeah, me too but I don't doubt what the others have seen.....learn something new every day, I guess. It must have been a before/after certain date or something.
Re: 70 B-body white door plug kit [Re: DPelletier] #864558
11/27/10 08:55 PM
11/27/10 08:55 PM
MO
cdp Offline
cdp  Offline
MO
I need some white ones for my A12 also. I need 2 of the larger plugs and the 2 small rubber plugs. I took my originals out (that were white) the they dicentigrated due to dry rot.
Re: 70 B-body white door plug kit [Re: demon] #864559
11/27/10 10:31 PM
11/27/10 10:31 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
These are often missing, larger plugs are easy to find in black but I have found the colored ones dont hold up well just like other colored polypropaline parts that are chalky. Heres a green one from a 69 B body with numbers on back if this helps. 3439286
72649
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 70 B-body white door plug kit [Re: mopargem] #864560
11/27/10 10:33 PM
11/27/10 10:33 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have to dig through my parts cans to see what color I have for my X. According to this I should have blue ones. I always figured they were all black plugs. Learn something new every day.
Re: 70 B-body white door plug kit [Re: 70HemiGTX] #864561
11/28/10 05:42 PM
11/28/10 05:42 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
To get this post on track and clear for everyone.
The 2 plugs that access the fasteners for the vent window bolts are always colored to the same upper door frame paint. All the OTHER plugs that go on the door (rear and bottom) are just plain black. I too need some white ones and want to know if repro's are available.
Re: 70 B-body white door plug kit [Re: hemi70se] #864562
11/28/10 07:16 PM
11/28/10 07:16 PM
okla.
O
okie Offline
okie  Offline
O
okla.
The ones on my 70 RR were white also, i could use some new ones too. I dyed some white but it isn't going to stay. Ronnie
Re: 70 B-body white door plug kit [Re: hemi70se] #864563
11/29/10 12:55 PM
11/29/10 12:55 PM
DPelletier Offline
DPelletier  Offline
Ahh! That helps! Thanks.
Re: 70 B-body white door plug kit [Re: DPelletier] #864564
11/29/10 09:22 PM
11/29/10 09:22 PM
Sounds like quite a few people are looking for these things. I guess they must not be available yet. It's a shame to think of how many I probably walked right by in the junkyards over the years and never thought there would ever be a day have trouble finding something like them.
Re: 70 B-body white door plug kit [Re: DPelletier] #864565
11/29/10 09:33 PM
11/29/10 09:33 PM
GMP440 Offline
GMP440  Offline
BlackhemiRR is correct on the colored plugs. 68' to 70' B-bodies had them to color coordinate with the upper metal door panels. Whatever the color upper part was painted it had a matching color plug. There was a little rubber plug in the center of the upper anel and a larger one at the front of the panel facing the front of the door jamb.
Re: 70 B-body white door plug kit [Re: GMP440] #864566
11/30/10 11:30 AM
11/30/10 11:30 AM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
www.megapartsusa.com Jamie will have them or be able to get them for you.
