Correct Horn for 70 GTX ? #862707
11/24/10 07:30 PM
11/24/10 07:30 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Somebody got a picture of the correct horn(s) for a 70 GTX ?
CHECK OUT MY NEW WEB SITE !
Re: Correct Horn for 70 GTX ? [Re: anlauto] #862708
11/25/10 03:03 AM
11/25/10 03:03 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Re: Correct Horn for 70 GTX ? [Re: anlauto] #862709
11/25/10 03:49 AM
11/25/10 03:49 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Assuming Dodge and Plymouth are the same here's an old thread with a good picture of the mounting;
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Correct Horn for 70 GTX ? [Re: Quikshft] #862710
11/25/10 04:16 AM
11/25/10 04:16 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
What about the relay in the first pic? Where does that go?
Re: Correct Horn for 70 GTX ? [Re: Quikshft] #862711
11/25/10 04:44 AM
11/25/10 04:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
My February '70 LA assembled GTX has horns w/bolt on brackets.
In '69 the relay bolts to the core support between the two horns - mine is missing , but I don't see were it is supposed to be?
Re: Correct Horn for 70 GTX ? [Re: anlauto] #862712
11/25/10 08:38 AM
11/25/10 08:38 AM
anlauto Offline OP
anlauto  Offline OP
Excellent thanks guys...Now I know what I'm looking for
Re: Correct Horn for 70 GTX ? [Re: 6bblgt] #862713
11/25/10 03:09 PM
11/25/10 03:09 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
My car is so botched up it had a '69 style regulator and engine harness, going to buy a '70 6V harness for it in time but in this picture the wires are coming from beneath the washer bottle, is the relay not under there then too?
Re: Correct Horn for 70 GTX ? [Re: Quikshft] #862714
11/25/10 09:59 PM
11/25/10 09:59 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
70 B-Bodys did not have the relay mounted on the core support or even in the engine compartment they had the horn relay mounted under the dash. It is a pretty unique piece. I will try to get pictures if no one else has them.
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: Correct Horn for 70 GTX ? [Re: SixPackRT] #862715
11/25/10 11:43 PM
11/25/10 11:43 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Cool, my dash is apart so I can check easily to see if I actually have the right item. The pic below is the part that I do have but my car was a basket case so it might not be right.
Re: Correct Horn for 70 GTX ? [Re: Quikshft] #862716
11/26/10 12:11 AM
11/26/10 12:11 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
A pic of the 69 horns and relay..
Re: Correct Horn for 70 GTX ? [Re: Quikshft] #862717
11/27/10 03:20 PM
11/27/10 03:20 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Jeff/Alan, I stole this picture from E-bay so I didn't have to crawl under the dash of my car. But this is the correct 70 horn relay. It would be mounted under the dash just to the left of the column on the lip.
Scott
70 Coronet RT 440+6
Re: Correct Horn for 70 GTX ? [Re: SixPackRT] #862718
11/29/10 12:52 AM
11/29/10 12:52 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
OK Scott thanks. I can see the wires and connectors that much plug onto that item hanging under my dash. Will add it to my list of items to acquire.
