Re: Repro 4 speed hurst handle..push in style?
[Re: Dart 340]
#86270
07/09/08 01:35 PM
07/09/08 01:35 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I need the re-curve type because I have a pistol grip on it. I could do that but prefer to keep her original on the shift body.
You want a bayonet style (push in) stick with a pistol grip on it for an A-body, correct?
[Re: In_The_Pink]
#86271
07/09/08 02:01 PM
07/09/08 02:01 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Yes, but it has to have the right curve on it so I dont have to lean forward to shift it.
[Re: In_The_Pink]
#86273
07/09/08 05:28 PM
07/09/08 05:28 PM
Dart 340
moparts member
moparts member
Yes, do you have one?
[Re: ogopogo]
#86275
07/10/08 09:55 AM
07/10/08 09:55 AM
Dart 340
moparts member
moparts member
Im pretty sure I have a stock,original 70 A body hurst handle I would trade you for the pistol grip if you want to go to a stock type shifter.If you want a pistol grip in your dart there is only one that works good.You need a pistol grip from a 71 -74 b body,non-console.
That sounds really good, but I put a shift boot in that fits the pistol grip shaft and I think the A body shaft is rounded. Would you be interested in the one I have? I could make a good deal on it to lessen the burden of getting the one I need.
[Re: Dart 340]
#86278
07/10/08 02:01 PM
07/10/08 02:01 PM
Posts: 5,447 So Cal
Sinitro
So Cal
A couple of choices.. If you do want a stocker 70 push-in type, contact Wayne @ Brewers Performance. My preference is to use the aftermarket Hurst Competition + gate, includes shifter gate stops, bolts up to the transmission with OE bracket and the after-market pistol grip handle bolts rite on. Just my ..
