Repro 4 speed hurst handle..push in style? #86264
07/09/08 10:35 AM
07/09/08 10:35 AM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Any one know where to get the old push in style hurst handles? I can find the "bolt in" everywhere
but no repops of the push in styles.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86265
07/09/08 11:07 AM
07/09/08 11:07 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
In don't think they're out there. What body are you looking for? I might have a decent B body.
Re: Repro 4 speed hurst handle..push in style? [Re: 6pkaar] #86266
07/09/08 11:20 AM
07/09/08 11:20 AM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
I have a short "b" body style...but it may need to be rechromed.
Re: Repro 4 speed hurst handle..push in style? [Re: dwbiggs] #86267
07/09/08 12:32 PM
07/09/08 12:32 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I have an A body someone put a pistol shifter in. Not sure what body style, bit it's the shortest one
there was and it's nearly straight up. To shift this thing, I need a longer arm by say 10 inches......or
find a better lever. I was thinking this one was from an E body but not sure. I need the one with an offset curve in it.
Any help?
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86268
07/09/08 12:46 PM
07/09/08 12:46 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I dont know but I didnt want to spend the extra $$$ so I used a newer handle from summitand drilled my shifter and bolted it in. works for me
Re: Repro 4 speed hurst handle..push in style? [Re: Joshs68] #86269
07/09/08 01:14 PM
07/09/08 01:14 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I need the re-curve type because I have a pistol grip on it. I could do that but prefer to keep her original on the shift body.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86270
07/09/08 01:35 PM
07/09/08 01:35 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You want a bayonet style (push in) stick with a pistol grip on it for an A-body, correct?
Re: Repro 4 speed hurst handle..push in style? [Re: In_The_Pink] #86271
07/09/08 02:01 PM
07/09/08 02:01 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Yes, but it has to have the right curve on it so I dont have to lean forward to shift it.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86272
07/09/08 05:01 PM
07/09/08 05:01 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
top of post
Re: Repro 4 speed hurst handle..push in style? [Re: In_The_Pink] #86273
07/09/08 05:28 PM
07/09/08 05:28 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Yes, do you have one?
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86274
07/09/08 11:31 PM
07/09/08 11:31 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Im pretty sure I have a stock,original 70 A body hurst handle I would trade you for the pistol grip if you want to go to a stock type shifter.If you want a pistol grip in your dart there is only one that works good.You need a pistol grip from a 71 -74 b body,non-console.
Re: Repro 4 speed hurst handle..push in style? [Re: ogopogo] #86275
07/10/08 09:55 AM
07/10/08 09:55 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
That sounds really good, but I put a shift boot in that fits the pistol grip shaft and I think the A body shaft is rounded. Would you be interested in the one I have? I could make a good deal on it to lessen the burden of getting the one I need.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86276
07/10/08 10:19 AM
07/10/08 10:19 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
To answer the original question. No, the repro Hurst handles do not work in a push in application. They ignored the 70 (and early 71) crowd and made all of the new handles with the later bolt on style base, there are other differences as well but most are cosmetic. As mentioned an original 71 B-body bench seat handle works well in an A-body but not all of them were the bayonet (push in) style, some were bolt on, you need to get the right one or modify your mechanism to accept a bolt on handle.
*BTW, I believe Gunslinger sells one that resembles a 71 B-bpdy handle, it was made and sold to fit A-body cars. They may offer a slip in version, you'd need to ask them.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86277
07/10/08 11:07 AM
07/10/08 11:07 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock restored pistol grip shifters, including the one you need.
E-mail me if you are interested.
Re: Repro 4 speed hurst handle..push in style? [Re: Dart 340] #86278
07/10/08 02:01 PM
07/10/08 02:01 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A couple of choices..
If you do want a stocker 70 push-in type, contact Wayne @ Brewers Performance.
My preference is to use the aftermarket Hurst Competition + gate, includes shifter gate stops, bolts up to the transmission with OE bracket and the after-market pistol grip handle bolts rite on.
Just my ..
