1974 Cuda door sticker weight numbers #862342
11/24/10 08:51 AM
11/24/10 08:51 AM
Lake Elmo, MN
Evil Monkey Offline OP
Lake Elmo, MN
I'm trying to recreate the numbers on the door sticker of my 74 Cuda that got wiped away (with the help of some solvent) many years ago. The VIN and manufacture date are easy, and I can make up a MDH based on my SPD, but I can't find any info on what the weights should be listed as on the door sticker. I don't know if the weights are different based on engine/transmission - mine was originally a 318/904, or if they are the same for all 74 Cudas. Unfortunately, my money situation won't allow me to buy a reproduction sticker, so recreating the numbers is the best I can do. Anyone have a 74 Cuda door sticker, and can tell me what the weights are?
Many thanks in advance.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 1974 Cuda door sticker weight numbers [Re: Evil Monkey] #862343
11/24/10 11:15 AM
11/24/10 11:15 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Coming up with the right MDH or even the right date is going to be harder than you think. Accually you may never know what is correct if you don't have a picture of your origonal sticker. I say that because of what I found on my 73 Challenger.
927 SPD
10-72 on door sticker
121216 MDH (there is a typo...the first 12 should be a 10)
The SPD on the fender tag doesn't always match the door sticker and the MDH is going to be impossible to accuratly guess.
If no one comes through with the weights for you, I can see what my 73 Challenger says.
Re: 1974 Cuda door sticker weight numbers [Re: burdar] #862344
11/24/10 12:37 PM
11/24/10 12:37 PM
Lake Elmo, MN
Lake Elmo, MN
Fortunately, I do remember that the Manufacture Date on my sticker was 2-74. I do have the fender tag (but no broadcast sheet) and the SPD is 206. I know I'll never know what the actual MDH was on the sticker - no one knows what it should be now that the info is gone from the sticker. I just plan on putting something reasonable on there, like 020715 - as long as it's close. I would like to get the correct weights on the sticker, though - that's something I don't have to guess about, I can get it right. Your Challenger would probably be close to the same weights, but hopefully someone will post Cuda weights.
Re: 1974 Cuda door sticker weight numbers [Re: Evil Monkey] #862345
11/24/10 01:59 PM
11/24/10 01:59 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
If nobody answers this before then I can check my 'cuda when I get home tonight. It is an original paint survivor so it should all be there.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1974 Cuda door sticker weight numbers [Re: DPelletier] #862346
11/24/10 06:08 PM
11/24/10 06:08 PM
Lake Elmo, MN
Lake Elmo, MN
That would be great. Thanks
Re: 1974 Cuda door sticker weight numbers [Re: Evil Monkey] #862347
11/25/10 01:16 PM
11/25/10 01:16 PM
DPelletier Offline
DPelletier  Offline
I'll try to post a pic later on, but it says;
GVWR 4475 GAWR Front 2240 GAWR Rear 2235
Re: 1974 Cuda door sticker weight numbers [Re: DPelletier] #862348
11/25/10 03:55 PM
11/25/10 03:55 PM
Lake Elmo, MN
Lake Elmo, MN
That's exactly what I nedeed - Thank you.
Re: 1974 Cuda door sticker weight numbers [Re: Evil Monkey] #862349
11/25/10 04:51 PM
11/25/10 04:51 PM
DPelletier Offline
DPelletier  Offline
No problem at all!
If you still need a pic, let me know.
Re: 1974 Cuda door sticker weight numbers [Re: DPelletier] #862350
11/26/10 01:41 AM
11/26/10 01:41 AM
Lake Elmo, MN
Lake Elmo, MN
No pic needed - I've found a few different 74 door sticker pics on the internet, so I know what I need to in order to get the type correct on mine, but none were Cuda stickers so I didn't have the correct weights. Now I do. Thanks again!
