6.1 Hemi alternator #862332
11/24/10 04:46 AM
11/24/10 04:46 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Installing a 6.1 Hemi in an E-body. I remember reading somewhere that the new alternator (the one used on new cars with a hemi) will work with the stock old style mopar voltage regulator. Is this true?
Also anyone has a part number for the alternator?
Thanks in advance.
Re: 6.1 Hemi alternator [Re: Barnabas_Kriss] #862333
11/25/10 12:12 AM
11/25/10 12:12 AM
Texas
GG1charger67 Offline
Texas
Chrysler has changed the terminal plug connector in later model alternator(07 and newer)to a single field terminal(B circuit) and a field monitering terminal.The alternator is still externally regulated and the field is controlled by the pcm.Flat style voltage are A circuit regulators and will not work with the latest version Chrysler alternators.You can use the earliest version regulator(tall square style)that was used with the old round backs.It is a B circuit regulator,just get a solid state version.
It is really going to come down to what year of the donor car is as to what style alternator it is. Hope this helps. Jason
Re: 6.1 Hemi alternator [Re: GG1charger67] #862334
11/25/10 03:52 AM
11/25/10 03:52 AM
Thanks for the info. I have a new assembly line engine, which came without an alternator. So if I get an earlier than 07 alternator (dual field?) it would work with the flat 70-and later mopar voltage regulator?
Re: 6.1 Hemi alternator [Re: Barnabas_Kriss] #862335
11/25/10 12:51 PM
11/25/10 12:51 PM
Texas
Texas
That will work ,just get a pigtail for the back of the alternator terminal connector and it will make it easier to wire up.Jason
