Re: Save me alittle time: Adjusting front drums
[Re: polarconvert]
#86213
07/09/08 01:15 AM
07/09/08 01:15 AM
RapidRobert
I would open it up & check everything out & also see how much lining to drum clearance you have right now.
[Re: Ronnman]
#86219
07/09/08 11:16 AM
07/09/08 11:16 AM
Brake noise is almost never just caused by adjustment. You probably have something else going on.
have the shoes recently been replaced? Did you have the drums turned? Did whoever turned them "cut back" the ridge inside?
As others have said, grease, oil, etc on the lining is a big cause. Also, new shoes DO take some time to seat. It might be helpful, if these are new shoes, to have them "arced" IF you can still find anyone with an arcing machine
#86220
07/09/08 11:24 AM
07/09/08 11:24 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Heck just dirt or a small stone in the drums will/can cause some noise.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
