Re: Priming bare metal, need a sealer & prefer high build..
[Re: MadMopars]
#862087
11/23/10 08:54 PM
11/23/10 08:54 PM
Posts: 659 Boise Idaho
Boise Chall
Boise Idaho
I don't know about affordable but I don't think you want to cheap out on the foundation you plan to put all of the work you are about to do on top of. I use PPG epoxy on bare metal and if it's going to sit longer than 1 week I put Featherfill high build primer on it. If you do it that way you don't have to worry about adhesion problems with the epoxy and you can come back to it a couple months later if needed. Now if the car is getting wet like you say just put epoxy on it but when you come back to it you will need to scuff the epoxy and put another coat on it before you can start working. You might want to ask this question here http://www.autobody101.com/forums/viewforum.php?f=5 this is what these guys do for a living
[Re: MadMopars]
#862088
11/23/10 09:11 PM
11/23/10 09:11 PM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
I took my GY3 Challenger all the way to the metal when I redid it. I used PPG DP90LF on the bare metal after DA'ing it with 80 and cleaning it till nothing else would wipe off. Let that sit a few weeks, and then scuffed up the few places needing filler....and put the filler over the DP. After that, I sanded the whole car and shot it with PPG K38 primer. I did a few coats of the K38 along with guide coat till it was straight. Then I took it to the painter and said "Here...it's your turn!" I also used PPG base/clear on it. All the paint, from metal to done was about $1500. It looks as good today as it did 5 years ago when it was painted. Use some good epoxy primer of some kind on the bare metal. Some prefer etch primer under the epoxy. I have one car done with etch primer first, and the car above done just with epoxy. No problems with either paint job, so it's probably just a matter of preference. Good luck.
[Re: MadMopars]
#862089
11/24/10 10:36 AM
11/24/10 10:36 AM
Posts: 684 Milwaukee
ToddP
super street
super street
Milwaukee
SPI epoxy primer. Last time I purchased it, cost was $140 for 2 gallons sprayable.The price included the shipping. awesome stuff. DP-LF by PPG costs twice as much and is not as good The old PPG DP made 20 years ago was great.
[Re: Thackdaddy]
#862094
11/24/10 05:35 PM
11/24/10 05:35 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
[Re: 68CoronetRT]
#862095
11/24/10 09:28 PM
11/24/10 09:28 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Matrix makes a good epoxy primer. Just used it as a final prime/sealer for my W350. Filled 150 grit with 2 medium coats. It sprays with alot of peel if you reduce per the directions, but reducing 4:1:2 instead of 4:1:1 made it lay down like glass. Wet sands pretty well also. I paid $125 a gallon with the hardener.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
