Priming bare metal, need a sealer & prefer high build.. #862086
11/23/10 08:38 PM
11/23/10 08:38 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
What primer do you guys recommend for priming bare metal? I am prepping my car for paint and have been stripping it all the way down. The car has minor pits some places from surface rust so I prefer a high build and given that it will be awhile before I am ready to spray it with color I would like a sealer to prevent rust through assuming it gets wet or becomes humid again. I was at a paint shop today and a guy recommended a new product I beleive it was U-Pol or something close to that. It was a green and grey can and a gallon of it ran less than 100 bucks. He said it was made to apply to bare metal and depending on how much reducer I used it could be high build and a sealer. I am looking to paint the car myself and will probably go with a single stage factory color. Given that the car is going to be garage kept and used maybe once or twice a month at best I doubt it will see much abuse. I hate to spend big bucks on paint and primer so I am looking for a best bang for the buck primer. A similar PPG setup would run about 300 bucks but require several different primers he said. What do you guys suggest for quality thats also affordable?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Priming bare metal, need a sealer & prefer high build.. [Re: MadMopars] #862087
11/23/10 08:54 PM
11/23/10 08:54 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I don't know about affordable but I don't think you want to cheap out on the foundation you plan to put all of the work you are about to do on top of. I use PPG epoxy on bare metal and if it's going to sit longer than 1 week I put Featherfill high build primer on it. If you do it that way you don't have to worry about adhesion problems with the epoxy and you can come back to it a couple months later if needed. Now if the car is getting wet like you say just put epoxy on it but when you come back to it you will need to scuff the epoxy and put another coat on it before you can start working. You might want to ask this question here http://www.autobody101.com/forums/viewforum.php?f=5 this is what these guys do for a living
Re: Priming bare metal, need a sealer & prefer high build.. [Re: MadMopars] #862088
11/23/10 09:11 PM
11/23/10 09:11 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I took my GY3 Challenger all the way to the metal when I redid it. I used PPG DP90LF on the bare metal after DA'ing it with 80 and cleaning it till nothing else would wipe off. Let that sit a few weeks, and then scuffed up the few places needing filler....and put the filler over the DP. After that, I sanded the whole car and shot it with PPG K38 primer. I did a few coats of the K38 along with guide coat till it was straight. Then I took it to the painter and said "Here...it's your turn!" I also used PPG base/clear on it. All the paint, from metal to done was about $1500. It looks as good today as it did 5 years ago when it was painted. Use some good epoxy primer of some kind on the bare metal. Some prefer etch primer under the epoxy. I have one car done with etch primer first, and the car above done just with epoxy. No problems with either paint job, so it's probably just a matter of preference. Good luck.
Re: Priming bare metal, need a sealer & prefer high build.. [Re: MadMopars] #862089
11/24/10 10:36 AM
11/24/10 10:36 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
SPI epoxy primer. Last time I purchased it, cost was $140 for 2 gallons sprayable.The price included the shipping. awesome stuff.
DP-LF by PPG costs twice as much and is not as good
The old PPG DP made 20 years ago was great.
Re: Priming bare metal, need a sealer & prefer high build.. [Re: ToddP] #862090
11/24/10 11:42 AM
11/24/10 11:42 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
yep...the LF in the PPG means LEAD FREE
and its also not as good as the old stuff....but wont give the painter lung cancer either...
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Priming bare metal, need a sealer & prefer high build.. [Re: shanker] #862091
11/24/10 01:19 PM
11/24/10 01:19 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
If you ar going to do clear coat, be sure to buy a primer for use with clear coat. Regular laquer primer will not bond wit base correctly. The guy who painted my car use laquer primer and you just have to look at the paint and it chips down to the primer. My neighbor used the same paint with primer for a clear coat paint. He is a former BMW and Lexus painter. His paint does not chip like mine. I can't aford to strip back to bare metal so I just shoot anyone who touches my car (ha!ha!)
Re: Priming bare metal, need a sealer & prefer high build.. [Re: babarracuda] #862092
11/24/10 02:46 PM
11/24/10 02:46 PM
Tucson AZ,
Tucson AZ,
Two paints suppliers have now mentioned using a product made by U-POL. Anyone tried this yet? The other low buck option is put out by Transtar. Thoughts? I'm trying to pick it up today so I can prime over the long weekend...
Re: Priming bare metal, need a sealer & prefer high build.. [Re: ToddP] #862093
11/24/10 03:01 PM
11/24/10 03:01 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
'71 Duster
Re: Priming bare metal, need a sealer & prefer high build.. [Re: Thackdaddy] #862094
11/24/10 05:35 PM
11/24/10 05:35 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
SPI for primers and clears. Great quality, great prices, great customer service and FREE shipping. Former PPG guy.
http://www.southernpolyurethanes.com/Product%20lines.htm
Re: Priming bare metal, need a sealer & prefer high build.. [Re: 68CoronetRT] #862095
11/24/10 09:28 PM
11/24/10 09:28 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Matrix makes a good epoxy primer. Just used it as a final prime/sealer for my W350. Filled 150 grit with 2 medium coats. It sprays with alot of peel if you reduce per the directions, but reducing 4:1:2 instead of 4:1:1 made it lay down like glass. Wet sands pretty well also. I paid $125 a gallon with the hardener.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
