6 banger RT/SE? #861466
11/23/10 04:21 PM
11/23/10 04:21 PM
New Mexico
rr74cuda Offline OP
rr74cuda  Offline OP
New Mexico
Found a 70 Chally in a shed awhile back and it keeps haunting me. Dash vin shows as a 6 cylinder 70 Challenger RT (JS). Did these cars exist? If memory serves I think it also has a small back window like an SE. Special order? If you could get a Challenger R/T with a six banger,does anyone know how many were built? Thanks, Rob.
Re: 6 banger RT/SE? [Re: rr74cuda] #861467
11/23/10 04:24 PM
11/23/10 04:24 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
No such animal, no way, no how...
Standard engine for the R/T was the 383-4 bbl. Magnum.
Re: 6 banger RT/SE? [Re: rr74cuda] #861468
11/23/10 05:03 PM
11/23/10 05:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Could be an error when the VIN tag was made, wouldn't be the first time. Also make sure whatever it is you are using to decode is correct because the engine letter call out changed in 1970 , seems that happened every few years ....
Re: 6 banger RT/SE? [Re: JohnRR] #861469
11/23/10 06:53 PM
11/23/10 06:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
C is next to the V on a keyboard.
Re: 6 banger RT/SE? [Re: 6bblgt] #861470
11/23/10 10:53 PM
11/23/10 10:53 PM
New Mexico
rr74cuda Offline OP
rr74cuda  Offline OP
New Mexico
Yes c is close to v. Wouldn't that be a kick! I still wonder if it is there. Like you say could be a vin mistake. Wouldn't mind finding an oddball if it exist though
Re: 6 banger RT/SE? [Re: rr74cuda] #861471
11/23/10 11:47 PM
11/23/10 11:47 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ck the engine code on the fender tag
Re: 6 banger RT/SE? [Re: gtx6970] #861472
11/26/10 10:46 AM
11/26/10 10:46 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Well they did build slant "Road Runners."
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
