Page 2 of 3 1 2 3
Re: B1 Orignals Vs B1 MC's [Re: Cab_Burge] #861074
11/25/10 01:05 AM
11/25/10 01:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well here is what my current 525" B1MC motor manages to do. My 2850lb turd has been 167.84mph(1622' DA)all out and has been as fast as 157 at 10.90. Single 4 with oval ported MC's. You do the math and tell me what HP it makes, I already have the dyno sheets. It went 160 in the 3300+ lb 10.5 car it was in before. Have not had a chance to run it since we made some changes(cam and compression) but I dont expect any significant differences with the way it is now.
I too can only share what I have experienced. My last set of B1 originals flowed what the bench said they flowed. They were between 415-420 on two benches. The car they were in weighed 3470lbs and went 149 with a single 4 on a 10.5" tire. Dont have the DA but it was in the summer so for here that is typically 2200-3000'. Pretty basic combo of parts that seem to do ok for what it was.
I do agree it is very difficult to compare one head to another. The combos will never be the same, at least if you are trying to maximize power they wont. But then again I am a backyard hack at best so what do I know
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861075
11/25/10 02:12 AM
11/25/10 02:12 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've been running B1 originals for 10 years. If
you are starting from scratch, like no block, headers, pistons etc. and you are looking to make max HP you might want to consider the Predators. The MC's don't make that much more power. Al's are and exception. And for the cost, the PSO's look like better bang for the $ if you have headers, and an aftermarket block and such. Best Machine are good people as are others, on this site. JMO
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861076
11/25/10 12:21 PM
11/25/10 12:21 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
I will do the math for you, Pro systems has a racing calculator on his web site that seems to work well. Lets see what it says. 3300 lbs at 160 1069 HP, 2850 at 167.84 1065 HP your engine. 3470 at 149 907 HP your old car. My PSO 588 engine 2400 lbs 186.92 1239 HP. I was at Route 66 when I ran that and it was 4000 DA. What all this means is its the combination of parts that make the differance. My PSO heads are a big jump from the M/C head and is the best inline wedge head. The Preadtor head should be a lot better but so far it has not be the case in the cars I have seen using them. We have two to dyno at the shop, one a 588 and one a 636. The 588 is going to be a close test against my PSO engine, same CI, 55MM cams, Sheet metal intakes, dry sump oiling system and iron blocks. The TS head I have yet is see run better than whats out there and push rod angle and clearance, lets get real. It needs its own block and the flow numbers are not what you think. For a all out TS/TD engine I am working on a better deal than whats out there.
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861077
11/25/10 01:26 PM
11/25/10 01:26 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
Are you guys doing any more PSO's? Heard you sold the last pair in stock
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861078
11/25/10 01:55 PM
11/25/10 01:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So you make 170ish more HP than mine does. With 63 more cubes, one more carb, a dry sump, and I am VERY sure a LOT more cam than I have. I have no doubt that your PSO's are VERY VERY good heads. Mine is by no means maxed out now, the cam is fairly mild for what it is and we certainly could up the compression a good bit. Criminy my intake is not even ported, but a B1 intake is pretty big to begin with. FWIW my heads flowed 460cfm on Mike Dukes bench and 464 here locally when we freshened it up recently. I feel pretty confident that if I were to build a max effort 588 with my current heads yours would not be so far ahead of mine in the end. Just speculation of course but let us ponder the question. I am 63 cubes down on your PSO motor, no dry sump, no sheet metal intake and extra dominator. So how much more power can I make with these additions? Care to speculate? Do you disagree?
I am not sure I could justify the added expense of the PSO head given the Predator is out there at a similar price point. I know what is in my current heads, which were hand ported. Not knocking the PSO head, I know you guys put a lot of time, money and effort in to reviving/reinventing/designing the PSO and should be applauded and commended for your efforts.
From what I get out of your post you are stating I have no idea what I am talking about. Maybe I am taking it wrong but to quote you "It is posts like this that are full of wrong information. Have any of the people on this post even seen any of the B-1 Heads?" I can only assume it was at least partially aimed my direction. If you feel I sated something incorrect I cant help that I guess. But I stand by what I posted then and now.
You asked the question "How much power and how fast are the cars of the people with all the answers on this post" I posted my numbers and you did the math. Pretty close to what the dyno said.
I never made any claim about the PSO head, never seen one, never been around one so have no way to make any comparison as I choose not to go as much by what people claim as what I have seen with my own eyes.
lastly I have great respect for what you guys do. Just becuase I am not a professional engine builder does not mean I am totally clueless. The current engine I have is the first one I have ever had that I had someone build. At the power level I am at I feel more comfortable having someone else assemble it. My choice. Happy Thanksgiving
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861079
11/25/10 02:19 PM
11/25/10 02:19 PM
UK
602heavy Offline
602heavy  Offline
UK
Right that's it , gonna put all you guys on 'ignore this user' , keyboard jockeys.
Sorry guys just could'nt resist ...only messin around.
Re: B1 Orignals Vs B1 MC's [Re: 602heavy] #861080
11/25/10 02:24 PM
11/25/10 02:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I really am clueless actually. Just hate when other folks say it
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861081
11/25/10 02:40 PM
11/25/10 02:40 PM
SouthEast Michigan
P
P
SouthEast Michigan
You asked to do the math, do you think its easy to get 170 HP at this level? The dry sump is on the engine because of the g force on the leave and when the chutes are out. It does help with windage but I doubt its worth a lot of power. Your horse power claims go up on your engine with some of your newer posts. My point is it is easy to make claims and its one thing to do it. You are one of the few that race and have a engine with the heads that this post started about. Dont take it the wrong way, your cars runs good and you are working on it to make it better, good job. On the flow numbers, if you do not flow the heads on the same bench its just a number. We tested a lot of heads on the same bench to compare the heads. Air flow is not the only thing of concern with cylinder heads. More cubes does not always mean more power. We tested a B-1 M/C 588 CI, dry sump two carbs ect and it was down from mine about 125 HP. What people dont get is the PSO head we did has more port volume for bigger engines, taller install Ht for valve springs for higher lift cams because the flow does not fall off. Better rocker system for the added valve lift, to do this on a B-1 M/C need longer valves, custom rocker system and you have a smaller runner head. Sorry for the rant, Happy Thanksgiving.
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861082
11/25/10 02:45 PM
11/25/10 02:45 PM
MD
HEMI472 Online content
HEMI472  Online Content
MD
Re: B1 Orignals Vs B1 MC's [Re: HEMI472] #861083
11/25/10 02:51 PM
11/25/10 02:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No worries here Pete. Hope you have a great Thanksgiving and good luck next year on the race front!
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861084
11/25/10 08:29 PM
11/25/10 08:29 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
This may be BS, but, I have been told that the canted valve predator head has an advantage over the PSO because of the intake-exhaust simetrical design vs the inline design. People have commented that when you try to make 1200HP, you have a hard time keepng heads gaskets in it. So...what's your take on it? I have been disappointed with some of the predator motors performance, but just thought maybe it was the porting. I don't profess to be an engine builder either, but would like to know, and are you still selling the PSO's? I am still contemplating my next move when I'm done with the B1 originals, but my dragster has run 7.33@183 in Vegas although I'm sucking this weekend. Happy Thanksgiving all!
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861085
11/26/10 01:04 PM
11/26/10 01:04 PM
mi
dirty magnum Offline
mi
are you sure it ways 2400?
Re: B1 Orignals Vs B1 MC's [Re: dirty magnum] #861086
11/26/10 03:36 PM
11/26/10 03:36 PM
SouthEast Michigan
P
P
SouthEast Michigan
I used cometic headgasket and no problem, I would like to know who thinks that. Yes the car weight was right, I checked my scale sheet when I did it and it was 2395 with the 1.5 gallon cell not full.
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861087
11/26/10 04:36 PM
11/26/10 04:36 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Don't know if I have a right to chime in here, but, since I was the original owner, and was the one that made the decision to oval port Al Alguire's B1-MC's, I can atest to the flow and dyno numbers, at least, when I owned that engine. One thing that cracks me up about the people on this board, which is why I try NOT to post on here anymore, is the fact that everybody is always puffing out their chests, with flow numbers and dyno numbers??? Put the damn thing in a car, and see what you are really made of. I could care less if my old B1 motor made 2000 HP, if I would have put a stock converter and a 2.76 pegleg behind it, than the pretty 2000 HP number is thrown out the window. If the PSO was available when I built my engine, I would have certainly used them, but, they weren't, so I did what I thought was best, in Oval porting my heads. Good decision? Yep. Any regrets? nope. Happy that they have held up just fine for Al? Absolutley.
Back to my cave.......
Re: B1 Orignals Vs B1 MC's [Re: B1CUDA] #861088
11/26/10 04:45 PM
11/26/10 04:45 PM
Arizona
Chris'sBarracuda Offline
Arizona
Probably because Duke and Pettis aren't "Mopar" guys, so they couldn't possibly make those numbers if the die hard Mopar engine builders have trouble doing it..
Now.. Go eat more turkey, and get back to the ER.. Not your cave..
Chris..
Re: B1 Orignals Vs B1 MC's [Re: Chris'sBarracuda] #861089
11/26/10 04:56 PM
11/26/10 04:56 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Chris..
Amen, my friend, Amen.
Re: B1 Orignals Vs B1 MC's [Re: B1CUDA] #861090
11/26/10 06:36 PM
11/26/10 06:36 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i know i'm nobody....but you are right, there are some big azz ego,s around here.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: B1 Orignals Vs B1 MC's [Re: PETE@BESTMACHINE] #861091
11/26/10 10:04 PM
11/26/10 10:04 PM
mi
mi
you look at the front and back of your car , if the other guy put his motor in your roller his et and mph would be better than what it is in his old cuda. fact..
Re: B1 Orignals Vs B1 MC's [Re: Cab_Burge] #861092
11/26/10 10:19 PM
11/26/10 10:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hey I was just trying to help..But maybe I should have kept my opinion to myself and stayed in my hole.
FWIW No I dont think making 170 more HP at this level is easy. However, I feel pretty confident that my engine guy could make some pretty good steam with a 588 and my current heads if I were to turn him loose. Then again maybe not. Afterall He does do all this work in his parents backyard, for that matter my car was built in a garage. No wonder it is such a turd
Re: B1 Orignals Vs B1 MC's [Re: Al_Alguire] #861093
11/26/10 10:24 PM
11/26/10 10:24 PM
mi
mi
al both cars are nice but its not apples to apples. like you said nice home built car / rick jones pro stock car , just the body shape is a huge factor.
Page 2 of 3 1 2 3
