abs light and brake light on UPDATE
#860888
11/22/10 08:35 PM
11/22/10 08:35 PM
Posts: 766 Nashport, OH
chargers777
Nashport, OH
Truck is a 1997 dodge 1500 4x4 with 360.Can the speed sensor cause this or is it something else.The brake pedal feels fine with good braking.I checked the codes by grounding pin 13.It showed code 6 which was erratic speed sensor reading while rolling.I replaced the sensor.Didnt work so I took it back out and cleaned the mounting area really well (rust buildup)and replaced it.I have driven it about 50 miles with no lights coming on so maybe its fixed.Thanks to all who helped.
Re: abs light and brake light on
[Re: chargers777]
#860889
11/22/10 08:36 PM
11/22/10 08:36 PM
Posts: 320 Dallas, TX
71_Demon
Dallas, TX
Most likely rear speed sensor mounted on diff. I think its a dealer item only.
'71 Demon 383 auto
'12 Ram 2500 6.7 Diesel
[Re: chargers777]
#860893
11/22/10 10:34 PM
11/22/10 10:34 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
on that year dodge ram the speed sensor is in trans case(tail shaft) has nothing to do with abs. the rear abs sensor is in top of rear axle housing, runs off plate next to ring gear. could that one or left or right front sensors or wire split or rotted going to them
MOPAR OR NO CAR
[Re: chargers777]
#860894
11/22/10 10:50 PM
11/22/10 10:50 PM
hemigod426
was just thinking have not work on a 1997 ram in a while, do those just have rear abs? if so just replace rear axle sensor. or try cleaning it remember it gets metal gear chips on it and fails to read
MOPAR OR NO CAR
[Re: hemigod426]
#860895
11/22/10 10:54 PM
11/22/10 10:54 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
I was just looking it up on alldata and it mentions some have 4 wheel abs so it may have front wheel speed sensors
[Re: chargers777]
#860898
11/23/10 12:27 AM
11/23/10 12:27 AM
chache876
Costa Mesa, CA
I mbeleive mine has rear only abs.
use a DMM and check the sensor with the specs I posted earlier to test it. If it checks out inspect the wiring
[Re: chache876]
#860899
11/23/10 04:00 AM
11/23/10 04:00 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Most likely the speed sensor. Aftermarket does sell them, Carquest etc... Here is what mine looked like 01 Ram 1500
[Re: sthemi]
#860900
11/23/10 04:07 AM
11/23/10 04:07 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
check your fuses....
my 94 Ram had abs and brake light on ...had burned fuze on brake lights
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#860901
11/23/10 08:08 AM
11/23/10 08:08 AM
Posts: 1,377 Ohio
Todd
Ohio
Check the fuses both. The brake lights and the abs fuses. The codes can be read by grounding one of the pins if i remember its pin 13 in the dlc. Then read the flashes of the abs light. Btw the rear sensor should read around 1200-1500 ohms.
