art morrison ladder bar set up whos done one ? #860404
11/22/10 12:58 AM
11/22/10 12:58 AM
CA.
RAY1969CARS Offline OP
CA.
did you use the panhard bar is the kit any good??? i would like to put the kit in a 69 dart
Re: art morrison ladder bar set up whos done one ? [Re: RAY1969CARS] #860405
11/22/10 01:03 AM
11/22/10 01:03 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
panhard bar on the street, track locater for racing
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: art morrison ladder bar set up whos done one ? [Re: bigtimeauto] #860406
11/22/10 01:14 AM
11/22/10 01:14 AM
CA.
CA.
r u running this kit???
Re: art morrison ladder bar set up whos done one ? [Re: RAY1969CARS] #860407
11/22/10 01:21 AM
11/22/10 01:21 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No, i get all of my stuff like that from S&W race cars in spring City PA.1-800-523-3353 EXT. 116 Candi. tell her i sent you
http://www.swracecars.com/
Re: art morrison ladder bar set up whos done one ? [Re: RAY1969CARS] #860408
11/22/10 07:52 AM
11/22/10 07:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have that kit it's totally a street set up. I removed the panhard bar and changed the shocks.
Re: art morrison ladder bar set up whos done one ? [Re: Quicktree] #860409
11/22/10 09:31 AM
11/22/10 09:31 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i had an A.M. ladder bar kit with panhard bar in the '68 Dart for over 15 years.
other than the top of the panhard bar bracket that is welded to the rearend making a dent in the trunk floor from bottoming out a few times because i like the car to sit low ...i had zero problems
you should go with some better shocks/springs....PM sent
Re: art morrison ladder bar set up whos done one ? [Re: jughed] #860410
11/22/10 10:10 AM
11/22/10 10:10 AM
gregsdart Offline
gregsdart  Offline
Nothing wrong with the ladderbars, still working great for me after fourteen years. You should consider better shocks though, and any setup should have all the brackets boxed in for lateral strength.
Re: art morrison ladder bar set up whos done one ? [Re: RAY1969CARS] #860411
11/22/10 01:58 PM
11/22/10 01:58 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I have this kit in my Turbo Buick. Don't install the panhard bar like the picture. My bar was re-attached from the front bracket to the opposite rear bracket on the rear. If it is attached to the ladder bar tube as pictured, it will twist and fatigue the bar and eventually fail. My application was a heavy street car.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: art morrison ladder bar set up whos done one ? [Re: turbobitt] #860412
11/22/10 02:35 PM
11/22/10 02:35 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Allan G.
Thats is called a track locater or diagonal link not a panhard bar, panhard bars go above the rear from one side to the frame on the other. Street cars need panhard bars or watts linkage.
Re: art morrison ladder bar set up whos done one ? [Re: bigtimeauto] #860413
11/22/10 03:35 PM
11/22/10 03:35 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
My car had that exact kit and the best thing I ever did was install a new top bar and get some better shocks.
Re: art morrison ladder bar set up whos done one ? [Re: RAY1969CARS] #860414
11/22/10 07:45 PM
11/22/10 07:45 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...A Ladder Link allows for better adjustments to the pinion angle.
Re: art morrison ladder bar set up whos done one ? [Re: thehemikid] #860415
11/22/10 08:32 PM
11/22/10 08:32 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
What is the price difference between Art Morrison and Chris Alston? Chris makes way better stuff for racing.
A shock up grade will be needed.
www.cachassisworks.com
Re: art morrison ladder bar set up whos done one ? [Re: Biginchmopar] #860416
11/22/10 08:34 PM
11/22/10 08:34 PM
Carson City, Nevada
Carson City, Nevada
Re: art morrison ladder bar set up whos done one ? [Re: Biginchmopar] #860417
11/22/10 08:53 PM
11/22/10 08:53 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I ordered the Ladder bar kit , less the shocks from Morrison.
Re: art morrison ladder bar set up whos done one ? [Re: Biginchmopar] #860418
11/22/10 09:25 PM
11/22/10 09:25 PM
tboomer Offline
tboomer  Offline
I just bought that same setup from Alston..
