Re: art morrison ladder bar set up whos done one ?
[Re: bigtimeauto]
#860406
11/22/10 01:14 AM
11/22/10 01:14 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: Quicktree]
#860409
11/22/10 09:31 AM
11/22/10 09:31 AM
Posts: 1,229 In The Hills
jughed
In The Hills
i had an A.M. ladder bar kit with panhard bar in the '68 Dart for over 15 years. other than the top of the panhard bar bracket that is welded to the rearend making a dent in the trunk floor from bottoming out a few times because i like the car to sit low ...i had zero problems you should go with some better shocks/springs....PM sent
[Re: jughed]
#860410
11/22/10 10:10 AM
11/22/10 10:10 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Nothing wrong with the ladderbars, still working great for me after fourteen years. You should consider better shocks though, and any setup should have all the brackets boxed in for lateral strength.
[Re: RAY1969CARS]
#860411
11/22/10 01:58 PM
11/22/10 01:58 PM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
I have this kit in my Turbo Buick. Don't install the panhard bar like the picture. My bar was re-attached from the front bracket to the opposite rear bracket on the rear. If it is attached to the ladder bar tube as pictured, it will twist and fatigue the bar and eventually fail. My application was a heavy street car. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: RAY1969CARS]
#860414
11/22/10 07:45 PM
11/22/10 07:45 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...A Ladder Link allows for better adjustments to the pinion angle.
