Page 20 of 26 1 2 18 19 20 21 22 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #860214
02/25/14 03:01 AM
02/25/14 03:01 AM
Northern MN
cedarmachine Offline
Northern MN
Adding the US Car Tool Frame connectors plus other braces
Not trying to be critical, but I have a suggestion, if not just for future reference.
I think I would have had all the sandblasting done before welding the connectors and anything else in.
After blasting, you can use a "weld-through" primer on the captured areas that would be covered by the frame connectors. This way, it would not only improve the quality of the weld, it would prevent corrosion in the areas that are boxed in. Corrosion inhibitor could also be sprayed in through the gas discharge holes in the connector as well, but needs a clean surface to adhere to.
Welding on a corroded or dirty surface will cause the shielding gas contamination that perpetuates imperfections in the weld.
Re: 71 cuda pro touring project [Re: cedarmachine] #860215
02/25/14 09:18 AM
02/25/14 09:18 AM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Your not being critical,but your misinformed . Look at the beginning of the build thread, everything has been blasted and epoxy primed other than the outer body before any welding started.
Re: 71 cuda pro touring project [Re: johnscudashop] #860216
02/25/14 09:39 AM
02/25/14 09:39 AM
Northern MN
Northern MN
I see. I thought I was seeing quite a bit of structure work before the body was blasted. Those areas must have been done previously then.
Re: 71 cuda pro touring project [Re: cedarmachine] #860217
03/05/14 07:36 PM
03/05/14 07:36 PM
Mrytle Beach SC
Mrytle Beach SC
This picture shows where it was blasted and had weld thru primer when we welded in the frame connectors. I do this on all my cars. I also made sure this was done while the car on full suspension on a drive on lift.
Re: 71 cuda pro touring project [Re: johnscudashop] #860218
03/19/14 03:49 PM
03/19/14 03:49 PM
Mrytle Beach SC
Mrytle Beach SC
Shaved the shock towers for a cleaner look.
Re: 71 cuda pro touring project [Re: johnscudashop] #860219
03/19/14 03:51 PM
03/19/14 03:51 PM
Mrytle Beach SC
Mrytle Beach SC
Shock towers cut out
Re: 71 cuda pro touring project [Re: johnscudashop] #860220
03/19/14 03:52 PM
03/19/14 03:52 PM
Mrytle Beach SC
Mrytle Beach SC
Shock towers with the new flat plate welded in
Re: 71 cuda pro touring project [Re: johnscudashop] #860221
03/19/14 03:53 PM
03/19/14 03:53 PM
Mrytle Beach SC
Mrytle Beach SC
Ground smooth.. I also welded up some unessary holes to clean up the engine bay.
Re: 71 cuda pro touring project [Re: johnscudashop] #860222
03/19/14 03:55 PM
03/19/14 03:55 PM
Mrytle Beach SC
Mrytle Beach SC
I created a little more space under the hood without these. The Coil overs the RMS Alterkation don't require the shock towers anyhow..
Re: 71 cuda pro touring project [Re: johnscudashop] #860223
04/23/14 07:06 PM
04/23/14 07:06 PM
Mrytle Beach SC
Mrytle Beach SC
Welded up all the holes in the frame and floor pan.
Re: 71 cuda pro touring project [Re: johnscudashop] #860224
04/23/14 07:08 PM
04/23/14 07:08 PM
Mrytle Beach SC
Mrytle Beach SC
Finished welding the tunnel in
Re: 71 cuda pro touring project [Re: johnscudashop] #860225
04/23/14 07:09 PM
04/23/14 07:09 PM
Mrytle Beach SC
Mrytle Beach SC
1 more view
Re: 71 cuda pro touring project [Re: johnscudashop] #860226
04/23/14 07:11 PM
04/23/14 07:11 PM
Mrytle Beach SC
Mrytle Beach SC
Transmission cross member braces welded in.
Re: 71 cuda pro touring project [Re: johnscudashop] #860227
04/23/14 07:15 PM
04/23/14 07:15 PM
Mrytle Beach SC
Mrytle Beach SC
While the car was upside down ,I modified the rear outer wheel wells for clearance for the lowered stance.
Re: 71 cuda pro touring project [Re: johnscudashop] #860228
06/15/14 12:18 PM
06/15/14 12:18 PM
Mrytle Beach SC
Mrytle Beach SC
Thanks to J&C Auto restoration in Murrells Inlet SC for gently media blasting the outside body and epoxy prime.
Re: 71 cuda pro touring project [Re: johnscudashop] #860229
06/15/14 12:20 PM
06/15/14 12:20 PM
Mrytle Beach SC
Mrytle Beach SC
Epoxy prime
Re: 71 cuda pro touring project [Re: johnscudashop] #860230
06/15/14 12:21 PM
06/15/14 12:21 PM
Mrytle Beach SC
Mrytle Beach SC
Quarter installation and panel alinment is next
Re: 71 cuda pro touring project [Re: johnscudashop] #860231
06/15/14 01:29 PM
06/15/14 01:29 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
When did I miss the quarter panels being bad? Did cancer appear after media blasting?
Re: 71 cuda pro touring project [Re: MuuMuu101] #860232
06/15/14 02:47 PM
06/15/14 02:47 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Wow !! Whole lotta Fabbin' goin' on......
Troy
Houston Mopar Connection Club
Re: 71 cuda pro touring project [Re: MuuMuu101] #860233
06/16/14 09:28 PM
06/16/14 09:28 PM
Mrytle Beach SC
Mrytle Beach SC
Not too long ago quarter skins were the only option for our cars, many were installed incorrectly like the ones on my car. Full quarter panels saves on welding and body work. Since the car is going to be black , I also wanted to get rid of the welded body seam line so I dont get that dreaded ghost line that shows up when the sun shines on it. Another advantage is that I was able to blast in the areas I could not reach with the quarter panels on.
