Page 11 of 26 1 2 9 10 11 12 13 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #860034
10/26/11 05:35 PM
10/26/11 05:35 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Tacked welded in
Re: 71 cuda pro touring project [Re: johnscudashop] #860035
10/26/11 05:36 PM
10/26/11 05:36 PM
Mrytle Beach SC
Mrytle Beach SC
welded marker light delete front fender
Re: 71 cuda pro touring project [Re: johnscudashop] #860036
10/26/11 05:37 PM
10/26/11 05:37 PM
Mrytle Beach SC
Mrytle Beach SC
welded marker light delete rear quarters
Re: 71 cuda pro touring project [Re: johnscudashop] #860037
10/26/11 10:06 PM
10/26/11 10:06 PM
Mrytle Beach SC
Mrytle Beach SC
Trunk lock welded shut. I plan on using a remote trunk latch from a 70s Imperial
Re: 71 cuda pro touring project [Re: johnscudashop] #860038
10/27/11 08:43 AM
10/27/11 08:43 AM
Mrytle Beach SC
Mrytle Beach SC
I also deleted the antenna hole, I am going to run a remote antenna so its not needed.
Re: 71 cuda pro touring project [Re: johnscudashop] #860039
10/30/11 08:01 PM
10/30/11 08:01 PM
Mrytle Beach SC
Mrytle Beach SC
More progress,finished the rear brake assembly.I used Wilwood 11.9 disc set up on rear
Re: 71 cuda pro touring project [Re: johnscudashop] #860040
10/30/11 08:04 PM
10/30/11 08:04 PM
Mrytle Beach SC
Mrytle Beach SC
I make up custom 3/16 brake line from 25ft coil. From the master cylinder to rear calipers
Re: 71 cuda pro touring project [Re: johnscudashop] #860041
11/02/11 05:22 PM
11/02/11 05:22 PM
Mrytle Beach SC
Mrytle Beach SC
Added the A/C port(vintage air part # 34215-VOQ) to the RH inner fender, I am running the A/C lines thru the RH inner fenderwell to hide them from the engine compartment
Re: 71 cuda pro touring project [Re: johnscudashop] #860042
11/04/11 07:33 PM
11/04/11 07:33 PM
Mrytle Beach SC
Mrytle Beach SC
i am running a 3 point seat belt shoulder harness. These are my harness points tack welded in position. The lower mount was moved from the factory position
Re: 71 cuda pro touring project [Re: johnscudashop] #860043
11/04/11 07:33 PM
11/04/11 07:33 PM
Mrytle Beach SC
Mrytle Beach SC
lower mount
Re: 71 cuda pro touring project [Re: johnscudashop] #860044
11/10/11 05:27 PM
11/10/11 05:27 PM
Mrytle Beach SC
Mrytle Beach SC
I had to modify the front fender bucket area via a 1 3/4 in hole saw thru so I can fit the 5 3/4 in Halegen Bulbs. Some minor fitment was nessesary to all 4 buckest so the headlights would fit.
Re: 71 cuda pro touring project [Re: johnscudashop] #860045
11/10/11 05:28 PM
11/10/11 05:28 PM
Mrytle Beach SC
Mrytle Beach SC
hole thru for Halegen bulb
Re: 71 cuda pro touring project [Re: johnscudashop] #860046
11/10/11 05:30 PM
11/10/11 05:30 PM
Mrytle Beach SC
Mrytle Beach SC
As you can see the halegen bulb need clearance in the fender
Re: 71 cuda pro touring project [Re: johnscudashop] #860047
11/10/11 05:31 PM
11/10/11 05:31 PM
Mrytle Beach SC
Mrytle Beach SC
Halegen headlight front view
Re: 71 cuda pro touring project [Re: johnscudashop] #860048
11/11/11 11:37 AM
11/11/11 11:37 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
What brand are the lights? Is it a kit?
Re: 71 cuda pro touring project [Re: JS29R0B] #860049
11/11/11 05:42 PM
11/11/11 05:42 PM
Mrytle Beach SC
Mrytle Beach SC
This wasn't a kit ,I went to NAPA and bought 4 Halegen bulbs with the 5.75 housings for a 85 BMW 635 CSI. I didnt want to use flat lens housings or projector housings. This is the only way I could find without spending $$$ for a curved lens like the factory .
Re: 71 cuda pro touring project [Re: johnscudashop] #860050
11/20/11 05:58 PM
11/20/11 05:58 PM
Mrytle Beach SC
Mrytle Beach SC
I proceeded to shave the rear bumper. The factory fitment was way off.
Re: 71 cuda pro touring project [Re: johnscudashop] #860051
11/20/11 05:59 PM
11/20/11 05:59 PM
Mrytle Beach SC
Mrytle Beach SC
I cut the rear bumper brackets and sectioned then 3/4 inch
Re: 71 cuda pro touring project [Re: johnscudashop] #860052
11/20/11 06:00 PM
11/20/11 06:00 PM
Mrytle Beach SC
Mrytle Beach SC
another picture
Re: 71 cuda pro touring project [Re: johnscudashop] #860053
11/20/11 06:01 PM
11/20/11 06:01 PM
Mrytle Beach SC
Mrytle Beach SC
welded back together
