!!!! Update broke the race car with rearend pics!!!! #859569
11/21/10 07:20 PM
11/21/10 07:20 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
well i pulled the diff today and sure enough it broke a bunch of ring gear teeth and the pinioun does not look much better. I know you fast guys have broken 8-3/4 gears before. so dont know if you want to see another pic. but i will post one anyway.lol so going by the pic what caused it to brake? to much power,rear not set up right or did both cause it to brake? well at least i can say my car has to much power lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859570
11/21/10 07:49 PM
11/21/10 07:49 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i used to do that to mine only much worse but my car is 4,150 lbs.my guess would be TOO MUCH POWER
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859571
11/21/10 08:54 PM
11/21/10 08:54 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
What always happened to mine is I would break about 1/2 of a tooth off the ring gear. Then another 1/2 and again. Finally, the pinion would land on a spot on the ring gear where two 1/2 teeth were broken, then it would "shell" the ring gear at that spot. The damage was always done at the starting line. It finally pick up a broken tooth , between the ring and pinion when I lifted at the finnish line and momentarally lock up the rear end. Lucky for me it broke something else and turn it loose. Locked up rear end at 100 mph is not something I ever want to do again.
It was at that point that I put a Dana rear end in.
Brian Dunnigan
Re: !!!! Update broke the race car with rearend pics!!!! [Re: '72CudaRacer] #859572
11/21/10 09:08 PM
11/21/10 09:08 PM
mopar65 Offline OP
mopar65  Offline OP
well mine did not give me any notice untill it let go. well it did slow down just a very little from the last pass. i wonder if that is when it frist started to break on me? there is 2 more spots on my ring grear that have 4-5 teeth gone and yes i am really gad that it did not let go at 125.00 mph.that could of been very bad. mine let go before the 60 foot mark. man the last pass felt like it was going to be the best pass of the night untill it went boom. now i get to figure out if i am going to put my new gears in the 8-3/4 and try it again. or just drive it around on the street untill i can get the money saved up to build a dana glad to hear you made out ok with your car. i think my car should weigh 3400-3500 with me in it.
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859573
11/21/10 09:14 PM
11/21/10 09:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I had a feeling that's what you would find.
It does look a lot better than the one I broke though
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859574
11/21/10 09:18 PM
11/21/10 09:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
got to figure out if i am going to put my new gears in the 8-3/4 and try it again. .
Look up the defintion of insanity first
Re: !!!! Update broke the race car with rearend pics!!!! [Re: WILD BILL] #859575
11/21/10 09:23 PM
11/21/10 09:23 PM
mopar65 Offline OP
mopar65  Offline OP
hey got a pic? we can compare who broke the most lol
Re: !!!! Update broke the race car with rearend pics!!!! [Re: jcc] #859576
11/21/10 09:23 PM
11/21/10 09:23 PM
mopar65 Offline OP
mopar65  Offline OP
sure got a link?
Re: !!!! Update broke the race car with rearend pics!!!! [Re: WILD BILL] #859577
11/21/10 09:24 PM
11/21/10 09:24 PM
mopar65 Offline OP
mopar65  Offline OP
bill just really glad it was not the engine.
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859578
11/21/10 09:29 PM
11/21/10 09:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you really want go there with me
Bear in mind this also snapped the tail shaft off the trans
I've said it before and I'll say it again......
Never underestimate my ability to break stuff
Re: !!!! Update broke the race car with rearend pics!!!! [Re: WILD BILL] #859579
11/21/10 09:41 PM
11/21/10 09:41 PM
mopar65 Offline OP
mopar65  Offline OP
Ok you win whats with the blue grease/oil ??? never seen blue oil like that before. bill i think you are taking this blue thing a little bit to far jk.
Re: !!!! Update broke the race car with rearend pics!!!! [Re: WILD BILL] #859580
11/21/10 09:45 PM
11/21/10 09:45 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
O yea ive broken the caps off like Wild Bills and the tailshaft too. It must be the name and driving a Charger connection, i ran a 68 back in the 90s
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859581
11/21/10 09:52 PM
11/21/10 09:52 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You should see my brake lines and shift light
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859582
11/21/10 10:32 PM
11/21/10 10:32 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Minor detail. Slap some Mighty Putty on there, and it will all buff out. Green to White technology.
-Kenny
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859583
11/21/10 10:40 PM
11/21/10 10:40 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm not totally sure, but the Blue gear lube looks like Red-Line Shock Proof gear oil?
http://www.redlineoil.com/product.aspx?pid=43&pcid=8
Re: !!!! Update broke the race car with rearend pics!!!! [Re: 451Mopar] #859584
11/21/10 10:42 PM
11/21/10 10:42 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You can be sure now
That's what it is
FWIW, I didn't know it was blue when I got it
Re: !!!! Update broke the race car with rearend pics!!!! [Re: WILD BILL] #859585
11/21/10 11:34 PM
11/21/10 11:34 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
dude,,,,that looks familiar,,,,lol,,,,ps,,,that IS a Dana,,,so i guess you can break them,,,lol....
(note multiple broken teeth,,,,, )
Re: !!!! Update broke the race car with rearend pics!!!! [Re: mopar65] #859586
11/22/10 01:34 AM
11/22/10 01:34 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
You can NEVER have too much power! You just don't have enough rearend!!!!!! YET!
Re: !!!! Update broke the race car with rearend pics!!!! [Re: Bigbeep] #859587
11/22/10 03:01 PM
11/22/10 03:01 PM
tboomer Offline
tboomer  Offline
Bobby...The car ran pretty good!! Congrats!! Are you going to save up for a Dana??
Re: !!!! Update broke the race car with rearend pics!!!! [Re: tboomer] #859588
11/22/10 03:34 PM
11/22/10 03:34 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Here is whats left of my 8 3/4 from last year.. lol.. got off the phone with Strange Engineering the other day and the new Dana will be here before Xmas... never again... lol..
RS23L7 4-Speed
