Re: 1962 361BB MOPAR
[Re: moon]
#857461
11/19/10 12:51 AM
11/19/10 12:51 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I would be very suspicious of that HP stamping, typically all the fonts on the pad match.... That being a 62 block I can't say 100% but others here sure can...
And I agree why chase down a date coded engine that will cost quite a bit more to rebuild due to obsolete parts, won't perform as well due to smaller displacement & in general just doesn't make sense unless your planning on having the car judged in a OE judging format....
[Re: moon]
#857465
11/19/10 04:38 PM
11/19/10 04:38 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
I am currently rebuilding a 361 now.It is going in a completely original 66 Coronet that I want to keep original. Dollar wise it doesn't make alot of sense because of the non availability of pistons, and you can build a 400 cheaper. I reworked the 516 heads, put a 3.750 stroke crank in it, .040 quench, 10.0-1, had custom Diamonds made for it, with a DP4B intake. Using top shelf parts and machine work, I have about 3650.00-3900.00 into it. Does it make sense? Not really, but everybody and their brother has a 440.I guess I am a little different. Good luck
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: dart1962_440]
#857470
11/20/10 12:13 AM
11/20/10 12:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Let's see if I can get the pic to attach...
So apparently the jumbo HP is correct for a 62.... Learned something new....
[Re: maundmotorworks]
#857472
11/20/10 04:49 PM
11/20/10 04:49 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...The size of the stamp may very per assembly plant, & may very per Dodge or Ply. My 63 Ply shop manual shows a smaller HP than that, but again its 63 & Ply. Another catch is, this is a reissue manual, not an original. ...EDIT: Added Info & Pic
