1962 361BB MOPAR #857456
11/18/10 09:50 PM
11/18/10 09:50 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I got the Polara 500 and it has the wrong block. So I found a 361BB which has S36 then HP and the bottom looks like a 2. (I already checked the casting numbers that are on the bottom, 2205712.) Is the bottom supposed to be a letter or number? I cant read all of it from the picture so I need more eyes. What does the HP mean? Also does anyone know about these engines? Is it worth fixing for an original car or is it a boat anchor? The one I found is $300.
Re: 1962 361BB MOPAR [Re: moon] #857457
11/18/10 09:52 PM
11/18/10 09:52 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I think the lower ones are numbers. Looks like 1121...not sure. guys help me out
Re: 1962 361BB MOPAR [Re: moon] #857458
11/18/10 10:10 PM
11/18/10 10:10 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
HP means high performance
Re: 1962 361BB MOPAR [Re: gtx69] #857459
11/18/10 10:12 PM
11/18/10 10:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Whats the matter with the running driving engine that's in it now? After all it won't be the original engine even if it is the right size. The 400 is a better engine then the 361.
Re: 1962 361BB MOPAR [Re: stumpy] #857460
11/19/10 12:22 AM
11/19/10 12:22 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
The engine came out of 1962 Dodge Polara 500 that is just like mine. Whats the difference in the high performance 361 and regular 361?
Re: 1962 361BB MOPAR [Re: moon] #857461
11/19/10 12:51 AM
11/19/10 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would be very suspicious of that HP stamping, typically all the fonts on the pad match.... That being a 62 block I can't say 100% but others here sure can...
And I agree why chase down a date coded engine that will cost quite a bit more to rebuild due to obsolete parts, won't perform as well due to smaller displacement & in general just doesn't make sense unless your planning on having the car judged in a OE judging format....
Re: 1962 361BB MOPAR [Re: moon] #857462
11/19/10 03:25 AM
11/19/10 03:25 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Pistons(CR),distr,intake cam and carb.305 H.P.
Leave the gun.......take the Cannoli's....Mike
Re: 1962 361BB MOPAR [Re: 1_WILD_RT] #857463
11/19/10 06:59 AM
11/19/10 06:59 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I suppose your right, even though I know where to get all the parts to do it. Thanks for the advice, maybe I will keep the 400 thats in it.
Re: 1962 361BB MOPAR [Re: moon] #857464
11/19/10 08:22 AM
11/19/10 08:22 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
You certainly have a beautiful car. What are your future plans for it? Do you know what the rear end gear ratio is?
Re: 1962 361BB MOPAR [Re: moon] #857465
11/19/10 04:38 PM
11/19/10 04:38 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
I am currently rebuilding a 361 now.It is going in a completely original 66 Coronet that I want to keep original. Dollar wise it doesn't make alot of sense because of the non availability of pistons, and you can build a 400 cheaper. I reworked the 516 heads, put a 3.750 stroke crank in it, .040 quench, 10.0-1, had custom Diamonds made for it, with a DP4B intake. Using top shelf parts and machine work, I have about 3650.00-3900.00 into it. Does it make sense? Not really, but everybody and their brother has a 440.I guess I am a little different. Good luck
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 1962 361BB MOPAR [Re: Mr. T] #857466
11/19/10 07:58 PM
11/19/10 07:58 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Oh I plan on keeping it. Years ago P.A.W had all the parts for the 361, I don't know if they still carry them, but I figure I'll leave it as it is for now, even though I did find a 1962 361BB to go in it like it originally had. The engine is out of a 62 Dodge Polara 500. I still don't know if the 361 I found is an HP block and if so did it come with dual point distributor, dome pistons or bigger valves and heads?
I don't know what the gear ratio is yet, haven't got under the car to check it out.
Re: 1962 361BB MOPAR [Re: moon] #857467
11/19/10 08:32 PM
11/19/10 08:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
PAW recently closed their doors..
Re: 1962 361BB MOPAR [Re: 1_WILD_RT] #857468
11/19/10 10:48 PM
11/19/10 10:48 PM
dart1962_440 Offline
Here's the 361 HP engine from my 62 Sport Fury. Looks like same assembly date as yours.
In 62 for B-bodies the 361 was a 4bbl, "hot" cam, dual exhaust & dual point distributor and was rated at 305HP and 395 ft lbs torque.
Pat
Re: 1962 361BB MOPAR [Re: dart1962_440] #857469
11/19/10 10:50 PM
11/19/10 10:50 PM
Let's see if I can get the pic to attach...
Re: 1962 361BB MOPAR [Re: dart1962_440] #857470
11/20/10 12:13 AM
11/20/10 12:13 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So apparently the jumbo HP is correct for a 62.... Learned something new....
Re: 1962 361BB MOPAR [Re: 1_WILD_RT] #857471
11/20/10 09:20 AM
11/20/10 09:20 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Not just '62, I've had many other year blocks come through my shop that had the same HP stamping in big letters.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: 1962 361BB MOPAR [Re: maundmotorworks] #857472
11/20/10 04:49 PM
11/20/10 04:49 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...The size of the stamp may very per assembly plant, & may very per Dodge or Ply. My 63 Ply shop manual shows a smaller HP than that, but again its 63 & Ply. Another catch is, this is a reissue manual, not an original.
...EDIT: Added Info & Pic
