Re: PROCHARGER VS. TURBO [Re: fastfish] #857299
11/19/10 03:07 PM
11/19/10 03:07 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I don't know what the typical cost of a blower kit would be but there is definatly more fab work with Turbo's. Based on my own experience with my turbo buick, I think the HP potential is much better with turbo's because theres more flexibility and options with turbocharging. Either way, I would do EFI with both.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: PROCHARGER VS. TURBO [Re: turbobitt] #857300
11/19/10 04:05 PM
11/19/10 04:05 PM
Northeast
fastfish Offline
fastfish  Offline
Northeast
Allan G.
I'd agree for the home-builder, but if someone wants to buy a high-quality kit designed to last, we offer them along with our supercharger systems.
turbo kits for mopar cars and trucks
turbo mopar price sheet
73 Challenger 8.518 @ 158MPH, 1970 turbo duster in the works...check us out at www.youtube.com/sdconcepts
and www.facebook.com/sdconcepts
We can also be seen in the December 2008 issue of Mopar Muscle magazine!
Re: PROCHARGER VS. TURBO [Re: bigtimeauto] #857301
11/23/10 12:54 PM
11/23/10 12:54 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I've set up both for drag cars and I'll tell you this:
The turbo is A LOT easier to control at launch.
The Procharger creates boost instantly which (at least on the engines I have done) blows off the tires or causes wheelies you don't want to do. With a turbo you can launch easy, hook up, and then the boost comes in for the rest of the race. Can be the difference between life and the alternative.
On the street the Procharger is more fun for the same reasons...
I have to disagree with this. a properly set up procharged car will go right down the track without any help. I do it regulary and i'm on true 10.5's
A procharged car can leave off idle, a turbo can't
No need for a boost controller with the procharger as the boost is directly associated with RPM
i have more but lets let the turbo guys come up with their pros
Our 135 Procharger ran a best speed of 210 at 45 pounds of boost. Our twin turbo car with the exact same engine has gone 225.50 with 44 pounds of boost weighing 200 pounds more. Guess which makes the most power?
Re: PROCHARGER VS. TURBO [Re: BobR] #857302
11/27/10 02:33 AM
11/27/10 02:33 AM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
Turbo,s have a heck of a top end charge. But not many have a 1.17 60ft at 3,300 lbs. You can leave much harder with a procharger if you know how to tune the suspension. My friends mustange with a turbo will out mph mine by 5mph but i run 4 tenths faster.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: PROCHARGER VS. TURBO [Re: 526ciduster] #857303
11/27/10 04:53 AM
11/27/10 04:53 AM
QLD Australia
Keith Black® Offline
QLD Australia
Darren Beale
Keith Black Racing Engines®
Re: PROCHARGER VS. TURBO [Re: BobR] #857304
11/27/10 11:58 AM
11/27/10 11:58 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You didn't list the ET, so i'm going to guess the procharger ET'd better. Plus what was the comparative size of the twin turbo's inlets versus the single procharger?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: PROCHARGER VS. TURBO [Re: MIKES_DUSTER] #857305
11/27/10 01:07 PM
11/27/10 01:07 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I love threads like this one.
I'd say go ahead and go with the Procharger... That way when you want another performance increase - you can swap to turbos. ;>) LOL
Re: PROCHARGER VS. TURBO [Re: 526ciduster] #857306
11/27/10 02:03 PM
11/27/10 02:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's odd. There are several 4 second (1/8 mile) turbo cars around here.
- Stu Harmon
Re: PROCHARGER VS. TURBO [Re: feets] #857307
11/27/10 10:13 PM
11/27/10 10:13 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
Both cars run in the fours.
I did not see the part about twins. I was comparing single to single. my bad
Re: PROCHARGER VS. TURBO [Re: 526ciduster] #857308
11/27/10 10:24 PM
11/27/10 10:24 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
So your chassis is set up a little better than his when it comes to the hole shot. Nice job.
I'll stick with my turbos.
- Stu Harmon
Re: PROCHARGER VS. TURBO [Re: feets] #857309
11/27/10 11:13 PM
11/27/10 11:13 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Both can be made to go about as fast as most anyone wants but I prefer beltless.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: PROCHARGER VS. TURBO [Re: CW25] #857310
11/28/10 12:16 AM
11/28/10 12:16 AM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
We only ran one car belt drive and yanked the snout off the crank so we have only used gear driven since.
Re: PROCHARGER VS. TURBO [Re: feets] #857311
11/28/10 12:22 AM
11/28/10 12:22 AM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
I was not asking you to change just offering an opinion. Both are very fast and are close to the same price.
Re: PROCHARGER VS. TURBO [Re: 526ciduster] #857312
11/28/10 01:21 AM
11/28/10 01:21 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I understood your point. No biggie. I simply like turbos.
- Stu Harmon
Re: PROCHARGER VS. TURBO [Re: feets] #857313
11/30/10 01:35 PM
11/30/10 01:35 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It really depends on the power level too... you can buy a BW-S475 turbo for less then $600 brand new, or chinese MP stuff even cheaper if you dare.
Yes, you'd still need to build the hot side, and get a wastegate, but you can't even come close to touching that price with a procharged system at that HP level.
I'll have less then $2500 into my entire turbo build for my '62 (Turbo, wastegate, blow off valve, hot side piping, cold side piping, flanges, bands, clamps, hat, carb conversion, etc...)
But I'm doing it all myself too... if you had to pay someone to fab the piping, it certainly wouldn't be that cheap...
