E85 in Minnesota #857164
11/18/10 03:14 PM
11/18/10 03:14 PM
Princeton, MN
racingduster Offline OP
Princeton, MN
Im getting ready to Dyno my motor and they are running a lighter grade E85 here cause of the cold weather. Does anyone know where I can buy a 55 gal drum or a 5 gallon drum of e85 or e89? I found E98. If I mix E98 and the lighter E85 and test it till it reads E85+ would that be ok for the Dyno?
Americans will put up with anything provided it doesn't block traffic. - Dan Rather
Re: E85 in Minnesota [Re: racingduster] #857165
11/18/10 03:33 PM
11/18/10 03:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Call Rob Mix in St. Paul ........if anyone knows , he does.
http://www.e85carbs.com/
Re: E85 in Minnesota [Re: racingduster] #857166
11/18/10 06:35 PM
11/18/10 06:35 PM
PA
ajcasini Offline
ajcasini  Offline
PA
What I would do is take the E98 and add high test pump gas to it. This will make a good consistent mix for you dyno session.
If you have E98 mix 4.3 gallons with .7 gallon high test pump gas.
This will give you 85% mix.
Re: E85 in Minnesota [Re: ajcasini] #857167
11/18/10 10:09 PM
11/18/10 10:09 PM
NC
440Jim Offline
440Jim  Offline
NC
That is what I would do also. Verify it is really E98, and mix pump premium gasoline with it. If you have a good cheap supply of E98, and it is just for racing, I would set everything up to run E98???
Re: E85 in Minnesota [Re: racingduster] #857168
11/19/10 01:19 PM
11/19/10 01:19 PM
Centerville, MN
schwep Offline
schwep  Offline
Centerville, MN
Contact Federated Coops (their main office is in Princeton) or Beaudry Oil in Elk River...
Re: E85 in Minnesota [Re: schwep] #857169
11/19/10 04:02 PM
11/19/10 04:02 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Rocket fuels sells E-85 that I have found to be a VERY consistent mix. I know it can be purchased in 55-gallon drums. Never tried to get it in 5-gallon cans.
Re: E85 in Minnesota [Re: ProStDodge] #857170
11/19/10 04:16 PM
11/19/10 04:16 PM
PA
ajcasini Offline
ajcasini  Offline
PA
It is a very consistent mix from Rockett and is a great race fuel but last time I checked it was around 6.00 a gallon.
Re: E85 in Minnesota [Re: ajcasini] #857171
01/19/11 11:03 AM
01/19/11 11:03 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
I would buy a drum of Achohol and mix my own
Kevin
Re: E85 in Minnesota [Re: ajcasini] #857172
01/19/11 12:05 PM
01/19/11 12:05 PM
NC
440Jim Offline
440Jim  Offline
NC
Post deleted.
I now see the last response was to an outdated topic, bringing it back to the top.
Re: E85 in Minnesota [Re: 440Jim] #857173
01/19/11 04:50 PM
01/19/11 04:50 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
I'm up against the same problem. Don't really want to dyno 13.4 to 1 on E70. One would think with all the alcohol plants up here E98 would be easy to get. I too am still looking for a direct outlet.
Re: E85 in Minnesota [Re: Maximus_Wedges] #857174
01/19/11 08:30 PM
01/19/11 08:30 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
We're would you find the kit to test purity of E85.
Thanks for any info.
Re: E85 in Minnesota [Re: 604 Hemi GTX] #857175
01/20/11 01:20 AM
01/20/11 01:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Quick Fuels sells a tester
