Re: E85 in Minnesota
[Re: ajcasini]
#857167
11/18/10 10:09 PM
11/18/10 10:09 PM
Posts: 16,928 NC
440Jim
NC
What I would do is take the E98 and add high test pump gas to it. This will make a good consistent mix for you dyno session.
If you have E98 mix 4.3 gallons with .7 gallon high test pump gas.
This will give you 85% mix.
That is what I would do also. Verify it is really E98, and mix pump premium gasoline with it. If you have a good cheap supply of E98, and it is just for racing, I would set everything up to run E98???
[Re: ajcasini]
#857172
01/19/11 12:05 PM
01/19/11 12:05 PM
Posts: 16,928 NC
440Jim
NC
Post deleted. I now see the last response was to an outdated topic, bringing it back to the top.
[Re: 604 Hemi GTX]
#857175
01/20/11 01:20 AM
01/20/11 01:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We're would you find the kit to test purity of E85. Thanks for any info.
Quick Fuels sells a tester
