Mini-Starter Installation #856525
11/18/10 01:27 AM
11/18/10 01:27 AM
KY
65pacecar Offline OP
KY
Installing a mini-starter on a friends 383 and when I try to put the starter on the lower stud it will stop short about A 1/4" from sitting flush, if I remove the lower stud I can get the starter to sit flush but then I cannot get the stud to start. Any Ideas, I have installed mini-starters before without any issues, never seen this scenario. The starter is a new Denso unit bought from Mancini a few years ago that he is just getting around to using.
Re: Mini-Starter Installation [Re: 65pacecar] #856526
11/18/10 01:56 AM
11/18/10 01:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have had this very same problem with other mini starters. I was told that the centering nose that is supposed to fit into the bellhousing needed to be filed down a little. Be careful though, as removing too much will result in incorrect clearance and the starter will grind.
Re: Mini-Starter Installation [Re: Kern Dog] #856527
11/18/10 10:48 AM
11/18/10 10:48 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
i had to grind the block a small amount to get mine to fit correctly.(74 400 cid) i didnt need to grind the nose cone in my case.
71 scamp big block with 915 heads 727 trans
Re: Mini-Starter Installation [Re: 71scamp440] #856528
11/18/10 10:53 AM
11/18/10 10:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Same hear on a 440!
Re: Mini-Starter Installation [Re: Dodgem] #856529
11/18/10 11:53 AM
11/18/10 11:53 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
From the tech archives. Read down at the bottom.
http://www.moparts.org/Tech/Archive/elec/1.html
Re: Mini-Starter Installation [Re: stumpy] #856530
11/18/10 01:30 PM
11/18/10 01:30 PM
KY
KY
Thanks for the tips.
Re: Mini-Starter Installation [Re: 65pacecar] #856531
11/18/10 03:18 PM
11/18/10 03:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
There are actually 2 part #'s from Ma Mopar,one for small block & one for big block.DON"T ask how I know.Well,I smoked a starter at the track and bought a mini from one of the venders{MOPAR event @ e/town}Spent 1.5 hours grinding & fitting untill it went in & bolted up.Found out afterwards about the 2 different mini's
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Mini-Starter Installation [Re: hemi-itis] #856532
11/18/10 04:52 PM
11/18/10 04:52 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
A few years ago I walked in to Auto Zone and purchased a starter for a 1992 Dakota 318 engine. Bolted up with no problems to my 383. Life time warranty. Works great.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
