clearance between distributor cap and valve cover #85559
07/07/08 10:25 PM
07/07/08 10:25 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
How much clearance is preferred between the valve cover and the distributor cap?
Re: clearance between distributor cap and valve cover [Re: ryan053] #85560
07/07/08 10:27 PM
07/07/08 10:27 PM
I don't understand your question. What engine are you working on? What kind of distributor?
Normally, distributor caps "dont hit" the valve cover. "They" are just made that way
Re: clearance between distributor cap and valve cover [Re: ryan053] #85561
07/07/08 10:31 PM
07/07/08 10:31 PM
the rule of thumb is 2.5 inches for every terminal on the cap.
Re: clearance between distributor cap and valve cover #85562
07/07/08 10:55 PM
07/07/08 10:55 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
its a 383 with a msd distributor and fabricated aluminum valve covers. I can get a credit card in between the cap and valve cover? How much clearance is acceptable?
Re: clearance between distributor cap and valve cover [Re: ryan053] #85563
07/07/08 11:01 PM
07/07/08 11:01 PM
Kirkland, Washington
Pacnorthcuda Offline
a credit card. Why would you need more?
Re: clearance between distributor cap and valve cover [Re: Pacnorthcuda] #85564
07/08/08 03:48 AM
07/08/08 03:48 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
with my victor heads I had to grind the valve cover to get a credit card in there.
Re: clearance between distributor cap and valve cover [Re: 70blackfish] #85565
07/08/08 04:09 PM
07/08/08 04:09 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I had to grind the Mopar Performance aluminum B/RB valve covers alot when I installed a Pertronics billet distributor. A credit card gap would have made me happy.
