Page 2 of 3 1 2 3
Re: Indy 440-1 users come on in! [Re: Barnstorm] #854642
11/16/10 12:56 AM
11/16/10 12:56 AM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Hey Sledgie,
Before my new Indy motor threw 2 rods out the block destroying the complete shortblock, it ran 8.97 at 149.9mph in a 2,850# Cuda.
It made 895HP on the dyno at 6,900 rpm.
Combo:
Indy max low deck Aluminum block. 540ci w/ 4.5 bore and 4.25" stroke. K-1 Crank, R&R 6.635" billet Alum rods w/ 2.20 rod journals.
Custom Ross domed 15:1 compression pistons w/ 1.205" comp height. Charlies Alum oil pan w/ milodon dual line swinging pick up and Melling HV pump.
Top end:
2100cfm Ron's Terminator Alcohol Injection on a low deck Indy manifold, 440-1 Alum heads 345cc intake volume CNC ported by MCH, 382 cfm @ .800"
Custom comp roller 286/294 dur @ .050", .782"/.765" lift, 111 lsa installed at 107 icl.
Headers: TTi 2" - 2 1/8" in chassis step headers, w/ Star Vacuum pump
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Indy 440-1 users come on in! [Re: moparniac] #854643
11/16/10 01:10 AM
11/16/10 01:10 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Great thread Sledgie!
Most of these combo's have fairly small cams and I've been told by several racers that 440-1 heads seem to really like a smaller cam unless you are running alot of compression and RPM's.
My car is 3200#'s with me in it, compression is somewhere between 11to1 and 12to1 , shift at 6600, trap at 6900, 4.30 gears with 29.5x10.5 tire.
My cam is a Cammotion roller 706/661 lift with my 1.5 rockers, 281/283 at .050, on a 104.
Last summer I had it installed at 106, everyone said that was wrong, that cam needs to be advanced. I put it in at 102 this summer and the car slowed down.
It has alot of overlap I'm told, and my cranking compression is only 150.
The car goes easy 9.90's in bad air and .80's in good air but I think a smaller custom cam will actually make my car quicker.
On the other hand, RonP's 440-1 motor runs real strong with a big cam. But his compression is up there some.
Re: Indy 440-1 users come on in! [Re: ProSport] #854644
11/16/10 03:30 AM
11/16/10 03:30 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
My old cam was a 283 @ .050", .683" lift single pattern. Naturally aspirated pump gas 4.5" x 4.15" 528, 11:1, aluminum block, home ported heads with 2.25" intake valves, Indy single plane with a dominator, 2" primary headers and 3" dual exhaust with mufflers. 781 hp at 6600 rpm, 704 ft-lb at 5000. Run 9.69/142.5 in a 3370 lbs in a street car with SS springs and DOT tires.
Plynouth VIP '67 TT IC EFI
Re: Indy 440-1 users come on in! [Re: jyrki] #854645
11/16/10 04:10 AM
11/16/10 04:10 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
home ported heads, checked & flow 360@600, 12:1 cr, 512 B block, ICH R1 roller 272/276@050 660 lift, 1050 dominator, 2950 with driver, 5600 stall, 4.88 gears, 32x14 slicks 9.55 on a bad day.
Re: Indy 440-1 users come on in! [Re: jyrki] #854646
11/16/10 05:17 AM
11/16/10 05:17 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Jyrki you have a pm. Rob.
Re: Indy 440-1 users come on in! [Re: rebel] #854647
11/16/10 05:19 AM
11/16/10 05:19 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
home ported heads, checked & flow [Email]360@600[/Email], 12:1 cr, 512 B block, ICH R1 roller 272/276@050 660 lift, 1050 dominator, 2950 with driver, 5600 stall, 4.88 gears, 32x14 slicks 9.55 on a bad day.
Nice shot of the val. wild man.
Re: Indy 440-1 users come on in! [Re: jyrki] #854648
11/16/10 06:42 AM
11/16/10 06:42 AM
U.S.
moparniac Offline OP
U.S.
looks like a nice combo!
seems most on here like the 280@50 and about .720ish lift range (as an average so far)
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854649
11/16/10 07:48 AM
11/16/10 07:48 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I did quite a lot of street driving, so I didn't want extreme lift and used endurance valve springs with pretty high assembled height; worked well.
Re: Indy 440-1 users come on in! [Re: moparniac] #854650
11/16/10 02:16 PM
11/16/10 02:16 PM
gregsdart Offline
gregsdart  Offline
3000 lb race weight, 6400 stall. TF trans. 4.56 gears 33 tall radial slicks.
Fully ported 440-1 heads,2.25 /1.81 valves. 15/1 compression. 4.5 bore 4.15 stroke Mega block 528 inch shortblock. 30 x 2 1/8 x 4 headers. First cam Isky RR 735, listed at 280/288/110 .765 intake lift with my 1.55 rockers, .685 exhaust lift. In at 110. dynoed 847 hp BUT I had to use 2 inch long tube dyno headers for the dyno session. Had a POOR PAN ON IT, and could only pull 1 inch vacuum in the motor on the dyno. After getting a good pan on it, my race headers and 7 inchs of vacuum, car went 8.77 at 153.16 mph with a poor 60 ft of 1.289.
I believe this motor likes a relatively short duration intake lobe (280 or less at .050) with lots of lift,.800 +. The heads still flow well up there.
I had a second cam specially ground for my combo, 283/296/112 with .775 lift intake 660 exhaust. Didn't seem to pick it up much if any. Cammotion spec'ed a cam with 281/284/110 in at 108 with .801 intake lift and 728 exhaust lift. I never bought that cam but kept the letter for information.
Re: Indy 440-1 users come on in! [Re: TheOtherDodge] #854651
11/16/10 05:47 PM
11/16/10 05:47 PM
Mo.
racerx Offline
racerx  Offline
Mo.
My 498 combo:
-1 home ported
Indy intake with stock 1050
12:1 compression
Scott Brown solid roller 259/265, .640/650, 112 lsa
I made about 720 hp based on ET and weight.
Just curious what weight,et.,car ?
Re: Indy 440-1 users come on in! [Re: racerx] #854652
11/16/10 05:53 PM
11/16/10 05:53 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
My 498 combo:
-1 home ported
12:1 compression
On motor only, in a 72 Challenger with 4000 converter, foot brake, 4.30 gear with 30" slick, through the mufflers weighing a tad under 3500 lbs, I went 9.87 @ 137. I didn't run it much on motor passes (like Monte ) because I set it up for nitrous, so Im sure if left a lot of ET on the table not doing tuning. I shifted at 6800 and crossed at 6900.
Re: Indy 440-1 users come on in! [Re: TheOtherDodge] #854653
11/16/10 06:12 PM
11/16/10 06:12 PM
Mo.
racerx Offline
racerx  Offline
Mo.
My 498 combo:
-1 home ported
12:1 compression
Pretty much the same setup but at 3350 with a 4800 conv.on 10.5w's with a best of 9.67@137
Re: Indy 440-1 users come on in! [Re: moparniac] #854654
11/16/10 07:43 PM
11/16/10 07:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All I can add is the pump-gas 499 440-1 engine that Herb McCandless & Co. built for the '95 Hot Rod Pump-Gas Big-Block Challenge ran a Cam Motion roller that spec'd 276/281 @ .050" w/ 110 LSA installed on 106 ICL. Lift was well over .700" w/ 1.7 Jesel rockers. McCandless didn't even care about quench then and ran flat-top pistons "way down" in the hole (something like .075" or .100", IIRC) w/ only 9.5 CR.
One of the tricks about that engine was that it had a lot of epoxy in the heads and manifold which were used to reduce the intake runner sizes and keep up the velocity. Too bad they didn't give either flow #s or runner cc sizes for those heads.
Re: Indy 440-1 users come on in! [Re: BradH] #854655
11/16/10 09:17 PM
11/16/10 09:17 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Our combo 578
bore 4.5430
callies crank 4.500 mopar mains, chevy rods
Oliver rods 7.25 .990 pin
Diamond pistons gas ported 14-1 comp
Crane cam 286 in, 306 ex at .050, .800 lift
Heads fully ported -1, jesel 1.6 rockers, psi dual springs, 2.300 intake, 1.78 exhaust with pushrod oiling
Milodon dual swing pickup w/ dragster pan
star vacuum pump 12in vacuum
2 1/8 headers
Motor made 914 hp at 6900, 800+tq at 5400rpm on vp c-12 with 1050 dom , now running alcohol on rupert 1250
9 in convertor ,1.80 glide w/brake
4.30 dana 60
car weighs 2947 w/ 50/50 distrubtion
has run 8.72 at 154.6 with no real chassis tuning. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Indy 440-1 users come on in! [Re: Mopar_racer_99] #854656
11/17/10 12:18 AM
11/17/10 12:18 AM
U.S.
U.S.
^^ why 2.30/1.78? 1.81 no good for ya? ^^^
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854657
11/17/10 02:54 AM
11/17/10 02:54 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
I wasn’t going to post but I had a little bit of luck making power with -1’s. My -1 engine went 169+ mph at 2470 lbs NA (never dyno’d so do the math), BUT my cam specs wouldn’t help 98% of the -1 users as it was way under headed. I spec’d it to maximize MY combination, it did have more duration than has been posted and the lift wasn’t as extreme as some have posted.
The cam is the single most important part of your engine and should be designed to give the maximum amount of air/fuel that YOUR engine/car needs and at the proper time. What everyone else is using is useless. Port volume, flow, cu in, intake, exhaust, compression ratio to make max dyno HP or torque. Then throw in car variables for best ET, weight, trans, converter, rearend, etc. Is the engine over or under headed? Don't be afraid to change lobe profiles with the same duration either.
Last one I had done the grinder didn’t like my spec’s and had something better. Lost .15 and 3mph, had one ground to what I thought and got back the .15 + .1 and the 3mph + 4 more. Was I lucky? Probably but you know the old saying “an engine is just an air pump” think about your combo and how to get the air through it (don’t forget it has to come out also) and go from there. LSA and ICL are VERY important to the complete combination. Just be careful of the broad internet statements, they like xxx duration, xxx lift, split, etc as they may or may not be true with your combination.
Re: Indy 440-1 users come on in! [Re: moparniac] #854658
11/17/10 08:25 PM
11/17/10 08:25 PM
Woodstock , Georgia
Woodstock , Georgia
Valves too close together to run the bigger exhaust valve. John
Re: Indy 440-1 users come on in! [Re: TS3303] #854659
12/07/10 09:10 AM
12/07/10 09:10 AM
U.S.
U.S.
Thx to everyone who took the time to list there cam specs and combos ... My cam should be here this week
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854660
12/07/10 11:22 AM
12/07/10 11:22 AM
BradH Offline
BradH  Offline
What was your final decision re: cam choice?
Re: Indy 440-1 users come on in! [Re: BradH] #854661
12/11/10 05:43 AM
12/11/10 05:43 AM
U.S.
U.S.
its a comp cam!
Mopar Performance
Page 2 of 3 1 2 3
