Page 1 of 3 1 2 3
Indy 440-1 users come on in! #854622
11/15/10 06:07 PM
11/15/10 06:07 PM
U.S.
moparniac Offline OP
U.S.
My block is finally back from the machine shop so its time to "cam up"
So all the dash one users on here if ya dont mind please post up your cam specs/compressions/power/et etc...
gonna be ordering a came here in the next couple weeks so need idears!
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854623
11/15/10 06:11 PM
11/15/10 06:11 PM
an8sec70cuda Offline
Talk to Dwayne, that's the only idea you need.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy 440-1 users come on in! [Re: an8sec70cuda] #854624
11/15/10 06:14 PM
11/15/10 06:14 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
X 2 Mine is .750/.730ish lift, 280-290ish @.050 on a 114 LC. I can get you exact specs when I get home. My motor is 557" and made right around 830-850 hp depending on the water temp.
Re: Indy 440-1 users come on in! [Re: an8sec70cuda] #854625
11/15/10 06:15 PM
11/15/10 06:15 PM
U.S.
U.S.
Im real curious about combos etc.... I got some changes going on
Mopar Performance
Re: Indy 440-1 users come on in! [Re: Bigcube] #854626
11/15/10 06:16 PM
11/15/10 06:16 PM
U.S.
U.S.
thx I appreciate it!
Mopar Performance
Re: Indy 440-1 users come on in! [Re: Bigcube] #854627
11/15/10 06:17 PM
11/15/10 06:17 PM
U.S.
U.S.
my old cam was a bullet 269/269 .430/.430 on a 110
Ive read from several people on here that the dash ones love a split duration!
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854628
11/15/10 06:42 PM
11/15/10 06:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
No Voodoo in cam design. No mystery to unlock, no hidden power to be had. Dont expect much, it just wont happen.
Unless the old cam is way off in duration or what the engine wants...it just wont happen. No magic duration to unlock hidden power.
I also suggest in getting the cam from Porter However, he will make sure the cam is correct in application....A fail-safe if you will.
Re: Indy 440-1 users come on in! [Re: Bob_Coomer] #854629
11/15/10 06:45 PM
11/15/10 06:45 PM
U.S.
U.S.
old cam is trashed and need a new one regardless. thx
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854630
11/15/10 07:01 PM
11/15/10 07:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
If i tell you what I use and I still beat you(RE I will race anybody) you wouldn't have any excuses for the whuppin on the street or at the track It's awfully hard to make a decent recommendation on the information provided so far about your combination, motor, trans, converter, rear gears and tire size, chassis, weight and so on
Re: Indy 440-1 users come on in! [Re: Cab_Burge] #854631
11/15/10 07:09 PM
11/15/10 07:09 PM
U.S.
U.S.
never asked for recomendations cab....
Im curious of the dash one combos and setups here!
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854632
11/15/10 07:13 PM
11/15/10 07:13 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
My 498 combo:
-1 home ported
Indy intake with stock 1050
12:1 compression
Scott Brown solid roller 259/265, .640/650, 112 lsa
I made about 720 hp based on ET and weight.
Re: Indy 440-1 users come on in! [Re: moparniac] #854633
11/15/10 07:29 PM
11/15/10 07:29 PM
I got one of them, recently dyno tested also
Re: Indy 440-1 users come on in! [Re: Cab_Burge] #854634
11/15/10 08:42 PM
11/15/10 08:42 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...A Sweet Pump Gas street motor
...10.28 cr
...499 cid
...-1's ported to ~350cfm
...Indy intake with 4150/Dom adapter (ported,polished, blended)
...1050 Dom
....575 262* @ .050 solid roller (Comp, Maximum street effort) discontinued I think. Good street cam.
...Pro-Gram cap'd iron block.
...694-724 hp (calculated with race gas)
...5.99 et. (1.33 60 ft. with 4 tire unloads in 1st gear & a light car)
...6 yrs on the street.
Re: Indy 440-1 users come on in! [Re: moparniac] #854635
11/15/10 08:52 PM
11/15/10 08:52 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
268-272 max on then intake duration. That 269/269/110 that you mentioned is probably pretty close.
8.30's @3400 lbs
Re: Indy 440-1 users come on in! [Re: Mike Swann] #854636
11/15/10 08:59 PM
11/15/10 08:59 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
496" 8.2:1 CR
440-1 heads, w/ Indy valve-job
260/268-112, .630/.630 solidroller
Re: Indy 440-1 users come on in! [Re: Mike Swann] #854637
11/15/10 09:02 PM
11/15/10 09:02 PM
U.S.
U.S.
My dash ones are the cnc 345s 2.25/1.81
Mopar Performance
Re: Indy 440-1 users come on in! [Re: moparniac] #854638
11/15/10 09:42 PM
11/15/10 09:42 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Here is mine.
CNC ported heads
jesel rockers and belt drive
1.7 rockers
12.5 comp
496 ci
bill miller pistons
eagle crank, Alum rods
Engine is in a 225 RED
Dyno
817 hp @ 7200 RPM
660 TQ @ 5500
Re: Indy 440-1 users come on in! [Re: moparniac] #854639
11/15/10 09:49 PM
11/15/10 09:49 PM
NC
440Jim Offline
440Jim  Offline
NC
You really should post your combo, because the cam is very dependant on the rest of the parts, CID, CR, stall speed, gear, tire dia, weight, etc. etc.
I am running a flat tappet (solid) at 13.5 CR in a 511 CID:
305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 143º/143º@.300", 112º/107º@.350", 0.433"/0.420" lobe lift, 110 LSA
Re: Indy 440-1 users come on in! [Re: Dabee] #854640
11/15/10 09:56 PM
11/15/10 09:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
275@50 ,, 585/w 1.5s I've got 1.6s on the intakes.... And my lifters don't roll, they turn.
Its a 383 though. 620 or so?
Re: Indy 440-1 users come on in! [Re: RemCharger] #854641
11/16/10 12:19 AM
11/16/10 12:19 AM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
2.25 intakes..1999yr good Knowlton port 385/295 flow..2in hookers..1150 dom on indy manifold..cam 294-288ex...741/693lift..500in 4.38x4.15..820hp..712tq
The little old lady from Pasadena is back!
Page 1 of 3 1 2 3
