Good Stock Replacement Clutch #853528
11/14/10 07:31 PM
11/14/10 07:31 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
I'm putting together a stock 383 for my 69 Dart with a 4-speed. What do you guys recommend for a clutch/pressure plate. Car is going to be a cruiser. I've been looking at the McLeod Street Pro 71509 from Summit. Just looking for a budget-minded setup with good quality.
Re: Good Stock Replacement Clutch [Re: kzinge1] #853529
11/14/10 07:33 PM
11/14/10 07:33 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
for a stock replacement you can't beat a Luk clutch set up
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Good Stock Replacement Clutch [Re: dusturbd340W5] #853530
11/14/10 07:49 PM
11/14/10 07:49 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I 2ns this choice Centerforce pressure plates are LUK ones with their weights added. I think is why you cant buy Centerforce disks by themselves. To prevent people from just switching the weights to a new LUK PP, which is a bunch cheaper then to buy it from CF.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Good Stock Replacement Clutch [Re: dusturbd340W5] #853531
11/15/10 01:15 AM
11/15/10 01:15 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
For a stock clutch replacement the LuK repsets are a good value. Here's the last one I used in a 1974 360 4-speed Duster
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280553021817
Re: Good Stock Replacement Clutch [Re: kzinge1] #853532
11/17/10 12:02 AM
11/17/10 12:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If your going to beat on it I would recommend a Center force dual friction. By far the best street clutch I have ever had. Many drag strip passes and street driving. Never slipped,smelled,chattered or even needed adjustment. This is in my small block Challenger,12.52@110 best. Over 100 passes with slicks.
Doug
