Which would be more fun, and faster? Auto vs. stick #85293
07/07/08 01:59 PM
07/07/08 01:59 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Real simple here. Would my car be more fun to drive with a 5-spd Tremec or my current 904 with a GV setup? Which would be a better investment, the automatic, or 5-spd? Originality is NOT an issue here. Nothing original about my Charger SE mild small block car. Will the 5-spd give me more power than the auto w/GV? I know they are both strong setups but I'm beginning to think that my car's potential will always be limited in front of the 904 tranny? My Charger is a driver, and I want to drive it alot and have fun while driving it, including to start taking it on a couple of 2-3 hour trips each year. The GV has a .78 overdrive and the Tremec that I'm eyeballing right now is the TKO-600 with the .64 overdrive. The car will keep it's current 3.91 SG's. Which would you choose for fun, if you could afford either one? Thanks
Re: Which would be more fun, and faster? Auto vs. stic [Re: 68Bullit] #85294
07/07/08 02:04 PM
07/07/08 02:04 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
My opinion is a manual is always more fun to drive. As for faster, I guess that's what you mean. Automatics are human error free for the most part.
You are not going to miss a gear with an auto, and you dont have the slight time lapse - power loss shifting. You can rev up a manual and dump the clutch without doing a neutral drop like in an automatic.
It's all a matter or preference.
Re: Which would be more fun, and faster? Auto vs. stic [Re: Dart 340] #85295
07/07/08 02:22 PM
07/07/08 02:22 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
autos are quicker and more cosistant in the 1/4 mile only.
manuals require less stuff and maintnence and are much more efficent on hills and turns.
autos are easier to install if the car was originally an auto.
I built an auto car,if i did it again it would be a manual.
Re: Which would be more fun, and faster? Auto vs. stick [Re: 68Bullit] #85296
07/07/08 05:32 PM
07/07/08 05:32 PM
northeast ohio
mkdart Online content
mkdart  Online Content
northeast ohio
Replaced the 727 in my dart with a TKO-600 ,5-speed(.64 fifth). It was pricey but it's a blast to drive. Mike
Re: Which would be more fun, and faster? Auto vs. stick [Re: 68Bullit] #85297
07/07/08 05:36 PM
07/07/08 05:36 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Trick question. Stick is more fun, Auto is faster.
The thing about this age-old debate is that in almost all cases, low-powered cars are faster in stick form due to parasitic losses of the automatic. High powered cars can afford these losses (the rear tires/suspension usually become the limiting factor)
Re: Which would be more fun, and faster? Auto vs. stick [Re: 68Bullit] #85298
07/07/08 05:45 PM
07/07/08 05:45 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The big Q to answer is this.... does your mild small block have the cajones to pull that big Charger with a .64 OD ?
Re: Which would be more fun, and faster? Auto vs. stic [Re: Dart 340] #85299
07/07/08 06:09 PM
07/07/08 06:09 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
...yep.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Which would be more fun, and faster? Auto vs. stic [Re: DPelletier] #85300
07/07/08 06:16 PM
07/07/08 06:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My opinion based post........
Manual is more fun
Manual is usually a bit faster (if it's an 833 trans that is) but NOT if it's a Kielser! They don't shift as Fast/Smooth as an 833.
Manual will get you better milage
Automatic is more consistant
Automatic is generally lower maintainance
If I were in your shoes I'd buy the Gear vendor unit regardless of if you run a 727 auto or an 833 4 speed if over drive is your goal, also look into Jamie Passons 4 speed OD unit, price is competitive and bullit proof..
Re: Which would be more fun, and faster? Auto vs. stic [Re: ScottSmith_Harms] #85301
07/07/08 09:04 PM
07/07/08 09:04 PM
MAN...
obviously some of you dudes never drove a manual valvebody trans car before.
Re: Which would be more fun, and faster? Auto vs. stick [Re: Pacnorthcuda] #85302
07/07/08 09:15 PM
07/07/08 09:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Manual if more fun but in general auto is faster. If you've got a 500hp car, auto will definitely be faster, but like he said, if you've got a low-powered car, IE more like 300hp, the stick may in fact be faster because of the extra gearing is now worth the time spent shifting. All-in-all no matter what, manual trans is always more fun, but if you're chasing ET's, auto is the way to go.
As for manual valve body autos, I dunno, just something about that conceptually turns me off. I mean what's the point of shifting manually if you don't have a clutch pedal to play with? I thought that was the whole point...
Re: Which would be more fun, and faster? Auto vs. stic [Re: DaytonaTurbo] #85303
07/07/08 09:24 PM
07/07/08 09:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Back in the day the 4 speed was deemed faster and rated according to NHRA as such. At that time there were numerous drivers out there both pro and non pro that new how to bang gears keeping the right to the floor and bearly touching the clutch pedal. don't see all that many now. They are there but in the numbers there were back then. Also the autos of the day were not quite as quick shifting as there were not the kits and valve bodies available then as now.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Which would be more fun, and faster? Auto vs. stic [Re: MoparforLife] #85304
07/07/08 10:20 PM
07/07/08 10:20 PM
440Demon Offline
440Demon  Offline
I agree with Scott - I run a "standard" Jamie Passon stick in a BB A body and love it. I had the same choice in front of me when I re-did the car between 02 and 05. Put the stick in and never looked back. Much like six flags, more gears = more fun!
John
72440Demon
Re: Which would be more fun, and faster? Auto vs. stic [Re: 440Demon] #85305
07/07/08 10:52 PM
07/07/08 10:52 PM
Upper Midwest
Upper Midwest
John
72440Demon
As you get older the more shiftless you get. I used to like it and knew how and could bang gears too but not no more.
Re: Which would be more fun, and faster? Auto vs. stick [Re: 68Bullit] #85306
07/07/08 10:56 PM
07/07/08 10:56 PM
Columbus, Ohio MAINTAIN RIGHT!
Max Rockatansky Offline
Spell Checker
Spell Checker
Musclecars should have clutches and big, burly shifters. Automatics are for gir...oops, here comes my wife, gotta go.
Press hard, four copies.
Re: Which would be more fun, and faster? Auto vs. stick [Re: Max Rockatansky] #85307
07/07/08 11:21 PM
07/07/08 11:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm 45, how old do I have to be to get tired of shifting? I'll answer for you, It would be after I'm dead!
I've driven just about every kind of automatic combo out there (manual valve body, reverse manual valve body, SS/DA car with 5,500 stall converters, heck even drove a clutch-flite a few times, remember those?), some are more fun than others and all are easier to drive than a stick, but none have come close to the fun factor a manual offers, not for me anyway.
Re: Which would be more fun, and faster? Auto vs. stic [Re: MoparforLife] #85308
07/07/08 11:24 PM
07/07/08 11:24 PM
Stick is always going to be more fun. Especially an 833
Re: Which would be more fun, and faster? Auto vs. stic #85309
07/07/08 11:32 PM
07/07/08 11:32 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
4 speed will always be more fun
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Which would be more fun, and faster? Auto vs. stick [Re: 68Bullit] #85310
07/08/08 12:52 AM
07/08/08 12:52 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Manual all the way. Would not even consider owning an automatic unless I was hurt or had bad knees and couldn't work the clutch and shifter. To date I have never owned any type of vehicle with an automatic, hot-rod or otherwise.
68 Roadrunner. 383 4-spd. Beat up.
Re: Which would be more fun, and faster? Auto vs. stic [Re: 73cuda340] #85311
07/08/08 12:57 AM
07/08/08 12:57 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
If you go with something with a quick first gear I think you'll like it better. Alot of the advantage of newer cars is the gearing that they get away with because of 5th and 6th speed overdrive. First gear is in the mid 3s:1 and differential is often in the mid to high 4s in these little engined sports cars. You dont need that much torque when youve got all that mechanical advantage on your side.
You think a 225 hp 300 ft lb of torque 302 would have propelled a late 60s Mustang to mid 14s like the 5.0s of the 80s?
3.35 first gear helps those cars alot.
Re: Which would be more fun, and faster? Auto vs. stic [Re: 68Bullit] #85312
07/08/08 06:05 PM
07/08/08 06:05 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
You've already had many responses concerning which is better but I will add another point.
I've watched the prices of Tremecs on the Mustang forums. It's a nice upgrade over the factory Mustang transmission too. As for investment.
Even used, like raced for 6 years used. These are still selling for $1600-$2000 and being sold FAST.
Also the internal rail shift mechanism feels like day one after thousands of miles.
