Re: Which would be more fun, and faster? Auto vs. stic
[Re: Dart 340]
#85295
07/07/08 02:22 PM
07/07/08 02:22 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
autos are quicker and more cosistant in the 1/4 mile only. manuals require less stuff and maintnence and are much more efficent on hills and turns. autos are easier to install if the car was originally an auto. I built an auto car,if i did it again it would be a manual.
[Re: Dart 340]
#85299
07/07/08 06:09 PM
07/07/08 06:09 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
It's all a matter or preference.
...yep.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: ScottSmith_Harms]
#85301
07/07/08 09:04 PM
07/07/08 09:04 PM
MAN... obviously some of you dudes never drove a manual valvebody trans car before.
Re: Which would be more fun, and faster? Auto vs. stick
[Re: Pacnorthcuda]
#85302
07/07/08 09:15 PM
07/07/08 09:15 PM
DaytonaTurbo
Manitoba, Canada
Trick question. Stick is more fun, Auto is faster.
The thing about this age-old debate is that in almost all cases, low-powered cars are faster in stick form due to parasitic losses of the automatic. High powered cars can afford these losses (the rear tires/suspension usually become the limiting factor)
Manual if more fun but in general auto is faster. If you've got a 500hp car, auto will definitely be faster, but like he said, if you've got a low-powered car, IE more like 300hp, the stick may in fact be faster because of the extra gearing is now worth the time spent shifting. All-in-all no matter what, manual trans is always more fun, but if you're chasing ET's, auto is the way to go.
As for manual valve body autos, I dunno, just something about that conceptually turns me off. I mean what's the point of shifting manually if you don't have a clutch pedal to play with? I thought that was the whole point...
[Re: DaytonaTurbo]
#85303
07/07/08 09:24 PM
07/07/08 09:24 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Back in the day the 4 speed was deemed faster and rated according to NHRA as such. At that time there were numerous drivers out there both pro and non pro that new how to bang gears keeping the right to the floor and bearly touching the clutch pedal. don't see all that many now. They are there but in the numbers there were back then. Also the autos of the day were not quite as quick shifting as there were not the kits and valve bodies available then as now.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#85304
07/07/08 10:20 PM
07/07/08 10:20 PM
440Demon
I agree with Scott - I run a "standard" Jamie Passon stick in a BB A body and love it. I had the same choice in front of me when I re-did the car between 02 and 05. Put the stick in and never looked back. Much like six flags, more gears = more fun! John 72440Demon
[Re: 440Demon]
#85305
07/07/08 10:52 PM
07/07/08 10:52 PM
MoparforLife
Upper Midwest
As you get older the more shiftless you get. I used to like it and knew how and could bang gears too but not no more.
[Re: Max Rockatansky]
#85307
07/07/08 11:21 PM
07/07/08 11:21 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm 45, how old do I have to be to get tired of shifting? I'll answer for you, It would be after I'm dead!
I've driven just about every kind of automatic combo out there (manual valve body, reverse manual valve body, SS/DA car with 5,500 stall converters, heck even drove a clutch-flite a few times, remember those?), some are more fun than others and all are easier to drive than a stick, but none have come close to the fun factor a manual offers, not for me anyway.
[Re: MoparforLife]
#85308
07/07/08 11:24 PM
07/07/08 11:24 PM
Stick is always going to be more fun. Especially an 833
#85309
07/07/08 11:32 PM
07/07/08 11:32 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
4 speed will always be more fun
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 68Bullit]
#85310
07/08/08 12:52 AM
07/08/08 12:52 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Manual all the way. Would not even consider owning an automatic unless I was hurt or had bad knees and couldn't work the clutch and shifter. To date I have never owned any type of vehicle with an automatic, hot-rod or otherwise.
68 Roadrunner. 383 4-spd. Beat up.
[Re: 73cuda340]
#85311
07/08/08 12:57 AM
07/08/08 12:57 AM
Posts: 5,161 CT
GTX MATT
CT
If you go with something with a quick first gear I think you'll like it better. Alot of the advantage of newer cars is the gearing that they get away with because of 5th and 6th speed overdrive. First gear is in the mid 3s:1 and differential is often in the mid to high 4s in these little engined sports cars. You dont need that much torque when youve got all that mechanical advantage on your side.
You think a 225 hp 300 ft lb of torque 302 would have propelled a late 60s Mustang to mid 14s like the 5.0s of the 80s?
3.35 first gear helps those cars alot.
[Re: 68Bullit]
#85312
07/08/08 06:05 PM
07/08/08 06:05 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Which would be a better investment, the automatic, or 5-spd?
You've already had many responses concerning which is better but I will add another point.
I've watched the prices of Tremecs on the Mustang forums. It's a nice upgrade over the factory Mustang transmission too. As for investment.
Even used, like raced for 6 years used. These are still selling for $1600-$2000 and being sold FAST.
Also the internal rail shift mechanism feels like day one after thousands of miles.
