retarded air grabber #851429
11/11/10 08:36 PM
11/11/10 08:36 PM
Space Station #5
471Magnum Offline OP
Space Station #5
The Air Grabber on my 72 Roadrunner is a bit S L O W.
Actually, it is delayed. After hitting the switch, it takes a good 10 seconds before it starts to open. Actually opens reasonably fast once it makes up it's mine to do it. It flips shut quickly without the delay.
What gives? Everything is hooked up right. No obvious vacuum leaks. No hissing.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: retarded air grabber [Re: 471Magnum] #851430
11/11/10 09:36 PM
11/11/10 09:36 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
How many inches of vacuum do you have @ idle?
Just my $0.02...
Re: retarded air grabber [Re: Sinitro] #851431
11/11/10 09:51 PM
11/11/10 09:51 PM
Space Station #5
Space Station #5
Haven't checked vacuum, but very mild cam.
I've actually hit the switch while engine braking to boost the vacuum and it made no difference.
-Jim
Re: retarded air grabber [Re: 471Magnum] #851432
11/11/10 10:24 PM
11/11/10 10:24 PM
I'd start by pumping up the nipple on the servo itself w a mityvac/vac pump to narrow down if the prob is the servo or in the vac supply to it
Re: retarded air grabber [Re: RapidRobert] #851433
11/11/10 10:28 PM
11/11/10 10:28 PM
Motor City
BeeFreak Offline
BeeFreak  Offline
Motor City
Mine is sort of the same way. Then when you get over 40 mph it flutters.
Re: retarded air grabber [Re: BeeFreak] #851434
11/12/10 02:06 AM
11/12/10 02:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
does your vacume can hold vacume ??????
I am truckless..
Re: Slow to react air grabber [Re: 471Magnum] #851435
11/12/10 09:37 AM
11/12/10 09:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think you could have chosen better wording for your thread .
Since it runs off vacuum to open you need to look at how much vac you have at idle, if it low because of cam choice I could see this happening .
