Max spring pressure for Crane gold rockers?
#850701
11/10/10 06:43 PM
11/10/10 06:43 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Just trying to do a little homework in advance. Considering a set of crane golds on my 318, just wondering what the spring pressure limit is before I'm pushing my luck. Thanks!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Max spring pressure for Crane gold rockers?
[Re: topfueldart]
#850702
11/10/10 07:10 PM
11/10/10 07:10 PM
Posts: 5,080 organ
maximum entropy
organ
word on the street is that the quality lately is suspect. i can tell you that i've had the same set in my car for 10+ years and 20,000 miles or so, with a variety of big hydraulic and solid cams, and they're still perfect under the microscope.
[Re: maximum entropy]
#850703
11/10/10 07:26 PM
11/10/10 07:26 PM
topfueldart
Renton Wa
The set I'm considering are several (5+) years old, but brand new in box. I realize this is a relative question, but I figured one of the engine builders would say 5 or maybe 600 lbs would be the limit before looking to jesels or similar. I think for a decent hydraulic or small solid roller I'll be looking at 400+ open, and thought I'd see if there were a consensus on the limit of an aluminum body rocker.
[Re: topfueldart]
#850704
11/10/10 07:48 PM
11/10/10 07:48 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
I run the crane golds with a 230lb seat pressure and 600lb open pressure. I have not had one problem with them yet, i do have my fingers crossed though.
65' Belvedere
496'' Stroker Indy Heads
[Re: mrpatel]
#850709
11/11/10 02:35 AM
11/11/10 02:35 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
here is mine 210 seat lbs. Went to a set of Sharps.
Its not the seat lbs thats going to break them. What was your open lbs. mike
[Re: 66er]
#850712
11/11/10 08:20 PM
11/11/10 08:20 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
I would use those 5 year old Golds, but change the adjusters, as the adjusters seem to be junk!!! Smith Bros makes good ones .
Yes I live in Michigan, so there is still 1 light on
[Re: mrpatel]
#850713
11/13/10 11:17 PM
11/13/10 11:17 PM
Posts: 167 mi
dirty magnum
mi
what year is on the rocker? is it a newer one? thanks
